HI everyone.
I recently bought a Lexmark 6350 all in one printer second hand.
I have downloaded the drivers and everything is running okay, but every page I print out has a perforated line down the right hand side.
I cant find any way of disabling this.
Any ideas?
Thanks in advance.
I have tried cleaning the nozzles, but this just improves the print quality.
There must be something inside that cuts the perforations onto the paper.
I'm not very technical, so I'm not sure what to do!?
Ahh.
You could be right Steve.
I've had a look inside and it appears one of the rollers is faulty and is cutting into the paper as it prints.
Hopefully it wont be too expensive to repair!
