Thread: Machine won't fire up
May 9th, 2007, 12:24 AM #21
sorry i was not more help but if you come up with a fix please post.
it's a problem i have not come across completely so im interested.Athlon64 4000+,Biostar NF4ST-A9,suntec 680W PS,atiradeon hd 2600 512mb PCIe ,2gig KingstonDDR400 PX800A DVDRW,silent939 k8 dual heatpipe heatsink
May 9th, 2007, 12:35 AM #22
Start of basic, remove/unplug everything except 1 vid card, cpu and 1 stick mem and see if you can get into bios. If you can then get into bios, one of your other hardware is faulty. If after removing other hardware and still cant get into bios, maybe mobo or psu is faulty. If you can get into bios after removing the hardare, start adding 1 piece at a time till you get the same malfunction, this will narrow down what is causing the fault.
May 9th, 2007, 03:14 AM #23
Could this be a power supply?
How can a machine shuts off when you tried to log on and all. So my guess would be the power supply.
If you have another power supply, try have it replace. See what happens. If everything else fails, wait for your mobo. Just a little help that I can do.If only the dead can speak, then we will know what's happening to us all next...
May 9th, 2007, 03:56 AM #24Junior Member
- May 2007
- 21
No problem this is the first time I've tried this, but I was at my wits end. Right now I'm "easter eggin" it! I'm a little upset with myself. I can usually figure a hardware problem out. Now software.......I'm lost from the git go! When I figure this out I'll definately let you know.
May 9th, 2007, 11:15 AM #25Ultimate Member
- Oct 2003
- Location
- Canada [Maritimes]
- 1,260
"I know for me I MUST remove any ide drives if want to use my sata drives.
Computer wil not respond if both installed. Or at least go to load xp."
i usually just change the boot order in the BIOS to which drives i
want to boot to
May 9th, 2007, 10:23 PM #26Junior Member
- May 2007
- 21
I tried both ways. Pulling the drive altogether and just changing the boot order.
May 9th, 2007, 10:26 PM #27Junior Member
- May 2007
- 21
I think you are on the right track. This system is in an 18 wheeler. I'm starting to think that it's not in the system at all. It may be the inverter I'm running to supply power.
May 9th, 2007, 10:34 PM #28Junior Member
- May 2007
- 21
I was thinking the mobo or the cpu. I'll know better tomorrow. I'll plug into a regular wall socket then.
May 10th, 2007, 11:16 AM #29Member
- Oct 2006
- 75
Transferring xp? you didnt just copy the files did you?
Anyway, thats not a windows problem, its a hardware problem..
Have you overclocked that CPU? Cus' it sounds like you system is overheating and then re-booting ( pc's do this is it gets to hot! well, most of the time..)
Its H/W problem, for sure.Speaking of beards and drugs, this leads me neatly to the Taliban.
May 19th, 2007, 11:33 PM #30Junior Member
- May 2007
- 21
Seems to have been the power supply. But now I don't get a signal to the monitor. Would that be because I can't hook up the 12v aux power on the mo
bo?
January 8th, 2008, 11:29 PM #31Junior Member
- Jan 2008
- Location
- Midwest
- 4
January 9th, 2008, 12:29 AM #32
Yes by using the fixmbr command.
Here is how to do it directly from microsoft.
http://www.microsoft.com/resources/d....mspx?mfr=true
the commands are written in the next section below.
"FIXMBR" is what you want.
might even want to do a "chkdsk -r" first as wellLast edited by quickoldcar; January 9th, 2008 at 12:35 AM.
January 9th, 2008, 01:34 AM #33Junior Member
- Jan 2008
- Location
- Midwest
- 4
Ok, so I'm booting from my XP Pro disk, I will get to the recovery console and run the FIXMBR and see what happens. I have unplugged the power to my other 2 IDE drives. Sound good so far?
I don't know much about the MBR but if it was using one on my previous IDE C drive until I deleted it, will there be an MBR on this SATA drive or does this command create one?
The CHKDSK -r is doing something...says:
CHKDSK is performing additional checking or recovery...
Ok, it seems to be stuck at 54%.
And what should I take away from these notes on the Microsoft site:
•If you do not specify a device_name, a new master boot record will be written to the boot device, which is the drive on which your primary system is loaded.
•If an invalid or nonstandard partition table signature is detected, you will be prompted whether you want to continue. If you are not having problems accessing your drives, you should not continue. Writing a new master boot record to your system partition could damage your partition tables and cause your partitions to become inaccessible.Last edited by CElloyd; January 9th, 2008 at 01:40 AM.
January 9th, 2008, 01:51 AM #34Junior Member
- Jan 2008
- Location
- Midwest
- 4
I tried to boot after FIXMBR and got Invalid partition table message.
Anymore ideas? I have information I'd rather not lose on this drive and the C drive for that matter. I may need to shop for a new drive to get a working Op System and then recover my data from there? I will be able to access this drive won't I??
FIRE!
By RedFury in forum IMO CommunityReplies: 4Last Post: July 11th, 2006, 08:21 AM -
2k machine can't see drives in XP machine. Ok reverse way.
By videobruce in forum Networking and InternetReplies: 7Last Post: January 30th, 2006, 08:33 PM -
Being set on fire probably didn't actually help, though
By Theophylact in forum IMO CommunityReplies: 11Last Post: April 19th, 2005, 09:54 PM -
Im on FIRE!
By DPA in forum Distributed ComputingReplies: 10Last Post: October 7th, 2003, 10:09 PM -
fire door
By SuperhumaNdhc in forum PC ModificationReplies: 4Last Post: May 21st, 2003, 01:24 PM
LOL I know what you mean, I like to watch a full season at a time too. Yep, last week was the season cliff hanger.
