Does your power supply have to be PCI-E to power a SLI motherboard??
Currently Active Users: 2685
Discussions: 200,963, Posts: 2,379,602, Members: 246,331
Old July 5th, 2007, 04:27 PM   Digg it!   #1 (permalink)
I have a 20pin power supply and my motherboard is SLI 24pin and i dnt know if its powering it correctly becuase it wont start properly. On some sites it says i need to set in bois my 12v supply to 36amp but my power supply says max 30A at 12v on the side. Is that causing my problem?
scottwba121 is offline   Reply With Quote
Old July 5th, 2007, 06:41 PM     #2 (permalink)
ph34r t3h g04t
Whir's Avatar
I would hazard a guess that you would actually need the missing 4 pin connector. If that's the case, it's time to get a new power supply. ~_~
Old July 5th, 2007, 06:42 PM     #3 (permalink)
Yea but , some sites say it still works does it? i am goin to order a new psu but dnt know what one i should order. could you suggest any? £20-40
Old July 5th, 2007, 07:05 PM     #4 (permalink)
You know on IDE harddrives is the power socket bit the same as on the newer PSU leads? because all the new psu's im lookin at have different power leads. sorry for bein so dumb lol
Old July 5th, 2007, 07:42 PM     #5 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
What your seeing is SATA connections on the newer PSU's. Most of the PSU's now-a-days have those, plus some 4 pin molex(ide) plug ins. Depending on how many molex plugs you need, you should be fine with most PSU's.
Most people on this site will recommend FSP. They are built to last, and are a very dependable PSU. Sparkle would be the other brand, it's just the same thing as FSP. You can pick them up for pretty cheap. Tagens are a good quality PSU also..
I myself have this one. And it runs a dual core, with a x1650 pro GPU, and 3 Hard drives and I have had no problems with it yet.
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old July 5th, 2007, 07:46 PM     #6 (permalink)
Thats 80W less than the one i have now. On some site it says my motherboard need 2 be turned up 2 36amps at 12v but this psu doesnt. is 500W high enough for AMD dual core 6000+ and asus m2n32-sli deluxe n 8600 gts oc??? i was gonna this one...
http://www.microdirect.co.uk/(17482)...U--3-year.aspx
thanks for ur help.
Old July 5th, 2007, 07:48 PM     #7 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
That OCZ is a very good choice.
I've never heard of any settings in the BIOS to compensate for the power supply.
Atomic Rooster is offline   Reply With Quote
Old July 5th, 2007, 07:50 PM     #8 (permalink)
I dunno. i cant get my other pc started it crashes just afta it goes past the bois bit. i think it might be my psu its a 20pin 1 and my mobo is a 24 pin 1. shall i go for that OCZ psu??
Old July 5th, 2007, 07:55 PM     #9 (permalink)
Instigator
Yea, running a 20 pin PSU on a 24 pin motherboard can lead to problems. The OCZ will be a great match for your motherboard and video card.
Old July 5th, 2007, 07:56 PM     #10 (permalink)
Ill order that PSU tomorrow and tell you how it goes. Thanks for your help
PCI Express connector from power supply? mad1 Graphics Cards and Displays 2 May 23rd, 2007 10:05 AM
good sli power supply gursukhmansidhu Processors, Memory, and Overclocking 5 January 10th, 2007 07:10 PM
sli capable power supply gursukhmansidhu General Tech Discussion 0 January 5th, 2007 06:09 AM
Do I need a new power supply 4 PCI-E Shoestrings Motherboards 4 November 11th, 2006 05:14 PM
New ASUS A8N SLI not booting. Power supply or motherboard? bail Motherboards 1 February 8th, 2006 11:15 PM
Is It Just Me? (2998)
Making Health Care Worse (181)
Laptop with wireless problem. (8)
windows vista security holes (14)
Print spooler problem (16)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Open With ..... Win7 (1)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
