Help!! Have I killed it??
Currently Active Users: 2647
Discussions: 201,002, Posts: 2,380,052, Members: 246,371
Old November 3rd, 2007, 09:24 PM   Digg it!   #1 (permalink)
PETE's Avatar
I have used Gigabyte easy tune software to reset default settings on a K8NS ultra mb..
Ever since it has beeped a memory error when attempting to start up. continuous long beeps.
The memory works fine in another mb.
I have tried clearing cmos & removing battery/shorting connections
It has a dual bios If that makes any difference.
I think I have killed it but I would love to save it if possible,
Pete.
PETE is offline   Reply With Quote
Old November 3rd, 2007, 09:44 PM     #2 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Nah, I don't think you killed it. Have you tried different memory in it? Try going into the BIOS and loading the "failsafe defaults" and/or manually setting the DRAM timings to auto.
Atomic Rooster is offline   Reply With Quote
Old November 3rd, 2007, 09:52 PM     #3 (permalink)
\m/(°-°)\m/
KarmaKiller's Avatar
Some boards take longer then others with the battery out method of clearing the CMOS. I've had one board take 5 mins, and another board took 1hour. It depends for some reason..
Folding for Team TechIMO!
Q6600@4ghz| Team Stats|
My RIG
Old November 3rd, 2007, 10:51 PM     #4 (permalink)
PETE's Avatar
Can't get into bios.. won't boot.
Old November 3rd, 2007, 11:25 PM     #5 (permalink)
Instigator
Do you have some different memory you can try in it? You could always try leaving the battery out overnight. I have some OCZ memory that did the same thing to me. It gave me fits trying to figure the damn stuff out. Give the contacts a nice cleaning with some alcohol or acetone. A little oxidation on the contacts could cause problems.
Thief is killed... Warthog IMO Community 103 September 7th, 2003 02:04 AM
I killed root the jester Applications and Operating Systems 8 February 1st, 2003 02:20 AM
I killed my Duron nunyadam Processors, Memory, and Overclocking 13 December 6th, 2002 11:42 PM
Almost killed a man MDS IMO Community 53 October 15th, 2002 10:22 PM
I think I killed it... SEALTEAMTHREE Technical Support 4 March 1st, 2002 07:32 PM
Is It Just Me? (3128)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
