sounds like your original problem could be jumper settings or your motherboard having a problem. If your HD is now having errors sounds like its something in the chain. Replace the IDE cable and see if you can get in. Since there are already errors, run the chk dsk just in case. Download some HD diagnostic tools from the manufacturer and see if there is anything wrong with it.
At this point your drive might be toast though, format and start over type approach.
