Results 1 to 4 of 4
    Jul 2007
    31
    Problems with rebuild
    Hi all,
    I've recently had a string of annoying problems with my Dell XPS. The most recent was that I wanted a new case but when I took my computer apart I found out that I could not use my Dell motherboard in my new non-Dell case. Upon putting it back together and connecting all the power chords I've had these problems:
    1 - The power light is orange rather than green and I can't find anything on Dell's website about this
    2 - When I plug in a flash drive into my USB ports it responds for a second but no interface devices (mouse, keyboard, etc) through these ports
    3 - If I plug only the power cable into my dvd-rom drive it will open and close, but if I plug the interface ribbon in it will not respond
    I know this is a very specific problem, but if anyone has had similar experiences or could help me out I'd greatly appreciate it.
    Senior Member Micro Bean's Avatar
    Feb 2003
    Worcester, MA
    670
    Just curious why Didnt the Dell Mobo fit in your case? Was it because the Mobo is a ATX Board and your new non dell case is a Micro ATX case? Kinda confused here.
    \\Opty 165 stock// \\ECS KN1 Extreme Lite//\\2gig Gskill DDR500//\\7800GTX 256mb Stock//\\Viper XG//
    THE Gimp Clown Fish! nemowolf's Avatar
    Jun 2007
    Bay Area
    4,936
    Which dell did you have to start with?
    1.If the lights are not displaying correctly, you plugged something in wrong.
    2.Again, you may have plugged the USB portion in wrong which is causing it to fail.
    3.Not sure on this one ...
    Since its an XPS, you should have bought a warranty and it is not the same as regular support. Look through your documentation and for that support number and get help from them. They have an entire department that specializes in only the XPS series of computers.
    PS: I have a XPS 600 and understand where your coming from for wanting a new case but its a really well designed case and you shouldnt need a new one other then for aesthetics. Once your done fixing this system and it works ... Build a whole new system because as you can tell its more of a pain then transplanting.
    Jul 2007
    31
    First off thanks for both of your posts. I actually took it back down to pieces and rebuilt and realized there was a small 4-pronged cable i missed on the first time and this caused each of the above problems.
    Now:
    Micro Bean - My Dell case opens on the right side, and similarly all the inputs on the board (USB, ethernet, video cards, etc.) are all on the right side of the mobo. The new case requires that the mobo inputs and card inputs are on the left, and if I flip my mobo it does not line up with the back of the new case because of its unique structure, namely the power supply being on the bottom.
    nemowolf - I did actually call Dell at one point and all they told me was that my phone support warranty had run out and didn't mention any further XPS warranty but I will look back just to make sure. The reason I was getting a new case was because I recently upgraded to a Geforce 8800 GTS card that gets pretty warm. This things huge so it leaves almost no room for any new fan or heatsink. But I definetely agree, once I've got this all settled I will definetely look into building a new system.
  1. Thinking of a rebuild
    By exally in forum IMO Community
    Last Post: February 26th, 2007, 09:32 PM
  2. Can you rebuild IE 6, like you could 5?
    By surreal in forum Applications and Operating Systems
    Last Post: June 3rd, 2004, 02:36 AM
  3. Rebuild Iraq - WHY?
    By Ed_S in forum IMO Community
    Last Post: November 30th, 2003, 11:55 AM
  4. win2000 rebuild
    By phil69 in forum General Tech Discussion
    Last Post: October 24th, 2002, 08:15 AM
  5. IE6 rebuild..?? In XP.
    Last Post: April 24th, 2002, 09:26 PM
