Weird annoying errors after fresh format
Currently Active Users: 2217
Discussions: 200,920, Posts: 2,379,018, Members: 246,286
Old December 26th, 2007, 01:12 AM   Digg it!   #1 (permalink)
Hi for some reason my computer has been experiencing some weird problems over the last week. I have done about 4 reformats in hopes of solving these errors but nothing is working. The current symptoms are as follows:
- sometimes a message box would pop up randomly saying fatal uncorrectable error and my computer would just restart
- my internet connection gets a limited or no connectivity and i have to repair it many times. this mostly happens when i go away from keyboard for a few minutes
- my vista theme suddenly turns into the classic xp white theme, everything closes, and my computer restarts
- 5 cmd.exe pops up and a ton of info is being processed extremely fast i dont even know what and sometimes after the problem just above this happens and restarts
- some applications freeze up and i cant click on the process or do anything in it until i end that process and start it up again
ex. explorer.exe or aim6.exe
they freeze up and i cant use the start menu or close the aim client with the x. when i try to, it makes a short weird sound. i have to end the processes and re open them
- sometimes my typing will get all messed up temporarily ranging from 10-30m. EDIT i just found out there has been some program named svchost.exe which acts like a autoit script in my system tray that seems to be disabling typing letters and spacing and such. i dont know where it came from because i have just done a fresh reformat and have not downloaded anything
Does anyone know what is wrong with my computer? is it a hardware issue or what?
Im running Windows Xp Sp2
Amd Sempron 2500+
1.74 ghz
512mb ram
Geforce 2 Mx/Mx 400 video card
2 Western Digital 40gb hard drives (one is a backup drive)
krzyazn is offline   Reply With Quote
format and fresh install ,, but were's my mouse eskippyca General Tech Discussion 17 October 19th, 2006 12:46 PM
Fresh Format.. 60GB used MoJoe Storage Related 5 December 28th, 2005 05:38 PM
Random ole32.dll errors after fresh install??????? Pipes1985 Technical Support 2 January 19th, 2004 06:01 AM
Weird annoying logon xVaMpYx Applications and Operating Systems 2 May 22nd, 2003 05:18 PM
Registry errors with fresh install... Timbob505 Technical Support 20 December 7th, 2001 10:43 AM
Is It Just Me? (2838)
Obama the Muslim (8)
Foreign voltage (7)
Print spooler problem (10)
Dept. of HS: NSA 'Helped' Develop V.. (14)
Help getting around port 80 for camer.. (0)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (30)
I need help getting around blocked po.. (0)
Virus Doctor Popup? (0)
Browsers wont load websites (0)
Dept. of HS: NSA 'Helped' Develop Vis.. (14)
SIS 740 and Widescreen (8)
PSP Go bought in Japan (0)
Foreign voltage (7)
Asus P4G8X Mobo (3)
Need hard disk drivers (4)
