USB Drive - SB Device not Recognized. One of the USB devices attached to this compute
Currently Active Users: 1848
Discussions: 200,935, Posts: 2,379,203, Members: 246,300
Old December 31st, 2007, 12:23 AM   Digg it!   #1 (permalink)
Exclamation
USB Drive- USB Device not Recognized. USB drive "malfunctioning"
Hi Folks,
I was getting messages that my pc wasnt running at USB 2.0... so i deleted the usb stuff... reboooted so it would reinstall the drivers... that didnt' work.
my sandisk 4gb micro cruzer said, u removed the device safely yadda yadda, be carefull next time message.... i said to myself ok sure...
so i read that my 2.0 settings in bios probably are disabled... i go and re-enable boot back up. try to get to my device and its blank and not autodetecting properly...(even though i had data on it)
i think, meh probably just a reboot will fix... so i reboot at i get "USB Device not Recognized. One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it"...
i think oh great pc is wack... so i try deleting the drivers in windows... reboot... they reinstall ... same message. i decide meh ill switch the bios back... working slow usb is better then not working usb... i reboot and still get the message....
i try checking on my laptop. same message.
try my sisters new laptop, same message...
souunds like this guy has the same problem...
http://answers.yahoo.com/question/in...7145846AAojaJL
is the drive dead? can it be fxed? i just baught it... i had sensative data on it. should i exchange it? what about my data? is it safe to say it wont be read?
Note: I looked around the web... this isnt one of those unplug system fixes ... as it seems thumb drive related.
Note: other devices work on the ports....
Note: If the drive is dead, can i somehow garanty the files are deleted on it?
I have a feeling i'm screwed.
System info:
-> XP home SP2
Property Value
MotherBoard:
ASUS: P5AD2-E-Premium Version Rev 1.xx
Chipset Vendor Intel Corporation
Chipset Model 925X/XE Host Bridge / DRAM Controller (C2 Step)
South Bridge 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge
SMBus Intel Corporation 82801FB (ICH6) SMBus Controller @0400h
Description Device ID
USB 1: Supported
USB 2: Supported
USB Root Hub USB\ROOT_HUB\4950CA4B2
USB Root Hub USB\ROOT_HUB\42E6F8F2D2
Unknown Device USB\VID_0000PID_0000\53468D1AA01
USB Root Hub USB\ROOT_HUB\41E463A9C2
USB Root Hub USB\ROOT_HUB\433B5830F2
Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 PCI\VEN_8086DEV_2658SUBSYS_80A61043REV_04\31158365 90E8
Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 PCI\VEN_8086DEV_2659SUBSYS_80A61043REV_04\31158365 90E9
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A PCI\VEN_8086DEV_265ASUBSYS_80A61043REV_04\31158365 90EA
Intel(R) 82801FB/FBM USB Universal Host Controller - 265B PCI\VEN_8086DEV_265BSUBSYS_80A61043REV_04\31158365 90EB
icevenom is offline   Reply With Quote
Old December 31st, 2007, 09:07 AM     #2 (permalink)
osprey4's Avatar
Try installing your chipset drivers?
Dual Monitor support with USB waynezo Technical Support 3 September 15th, 2008 05:32 PM
Trouble logging in on my Verbatim USB drive... Nikki8908 Technical Support 8 February 7th, 2008 03:16 AM
USB Drive - SB Device not Recognized. One of the USB devices attached to this compute icevenom Technical Support 1 January 3rd, 2008 10:18 PM
PC doesnot recognice my USB flash drive demha General Tech Discussion 1 December 11th, 2007 08:14 AM
USB Device Not Recognized. BattleToad Storage Related 1 January 4th, 2006 10:59 PM
Is It Just Me? (2889)
Wireless Televisions. (6)
Obama the Muslim (14)
windows 7 problem (0)
wireless user (0)
Modern Warfare 2 freeze (12)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
