Please help Monitor takes a while to come on when booting
Currently Active Users: 2716
Discussions: 201,002, Posts: 2,380,046, Members: 246,371
Old January 18th, 2008, 04:32 PM   Digg it!   #1 (permalink)
I was wondering why my monitor takes a while to come on when I turn on my computer. It's about a 10-15 second delay. enough to make people in my office believe the computer is not turning on. There is power to the monitor but I have a yellow light. It isn't until after the delay that the light becomes green and I get my display.
Please help me determine what the issue might be? Is it the system board, BIOS configuration or video card? I'm not sure and can really use the help asap.
Thank you!
firesweep is offline   Reply With Quote
Old January 18th, 2008, 05:12 PM     #2 (permalink)
When you start your computer there is a sequence of what devices the computer starts to power. The problem may be that your graphics card which turns your monitor on is not up on the list very high thus it starts a little later than all the internal components (CD drives, hard drives etc.). If you go into the BIOS by pressing [DEL] or whatever the designated key by your manufacturer is, you should be able to put you monitor up higher on the device boot list. Hope this helps although I don't exactly see the big deal in waiting 10-15 secs but w/e floats your boat.
Alexxander is offline   Reply With Quote
problems with booting duel booting drjekel_mrhyde Storage Related 4 December 15th, 2007 06:09 AM
Problem booting newly built PC. No signal recieved on monitor. (spec inside) cobain7513 Technical Support 23 July 25th, 2006 02:22 PM
Monitor Blank When Booting ekerns Technical Support 1 January 12th, 2004 11:40 PM
Do you have what it takes? Distributed Computing 22 January 27th, 2002 07:39 PM
Do you have what it takes? Distributed Computing 0 January 26th, 2002 09:19 PM
Is It Just Me? (3126)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Charge4All Black Friday Special (0)
Rar volume (number 7) (0)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
