Join TechIMO for Free!
Thread Tools
Currently Active Users: 1807
Discussions: 188,402, Posts: 2,243,615, Members: 232,634
Old April 27th, 2008, 11:45 AM   Digg it!   #1 (permalink)
TimeDeatH's Avatar
Send a message via MSN to TimeDeatH
Battlefield 2 problem
Ok i have recently downgraded to XP from vista. I was able to play battlefield 2 on high settings on vista. Now I have installed battlefield 2 back onto my computer (after installing ALL drivers) and it starts for a few seconds then closes to my desktop. It's patched to the latest patch too.
Don't know if this helps, but i see alot of things about battlefield 2 and the dual core being relative to making problems. I have a dual core.
TimeDeatH is offline   Reply With Quote
Old April 27th, 2008, 08:48 PM     #2 (permalink)
ShyguyXPC's Avatar
which dual core, intel or AMD? if AMD, download the AMD Dual Core Optimizer program/file, & run it...
also make sure DirectX 9.0c is updated to the very latest version.
if you were playing with High settings in Vista, you should have no problem running the game maxed out in XP... its probably one of the two I mentioned above, either DirectX isn't updated to absolute latest version (which was a problem I had running the BF2142 demo a year or so back, & heard similar problems with some with BF2), or if your running an AMD X2 CPU, running the Dual Core Optimizer might iron out some problems...
ShyguyXPC is online now   Reply With Quote
Old April 27th, 2008, 09:55 PM     #3 (permalink)
TimeDeatH's Avatar
Unfortunately, i have an intel dual core and have just updated directx 9 but, no luck. I'm thinking the problem maybe started around the time before i moved to XP when i was preparing. I changed something in my bios to IDE and had everything but battlefield 2 running smoothly. I tried the obvious and changed it back but that led to the blue screen of death. I changed it back and my OS was running fine, but still no luck for battlefield 2.
I have other games like counterstrike and half life 2 running fine so I'm not sure what the problem seems to be.
I am going to give you all the info I have discovered on this issue: My easyinfo (the processor speed varies for some odd reasons i have 2 1.46 ghz processors)
Your System Results Game Requirements
Operating System Microsoft Windows XP Professional Service Pack 2 (Build 2600) Pass Windows XP
System Memory 2038.9 Pass 512.0
Processor Speed -7561.8 Fail 1700 Mhz (1.7 GHz)
DirectX Version 9.0c Pass 9.0c
Display Device Mobile Intel(R) 965 Express Chipset Family Unknown Compatibility
Display Memory 256.0 Pass 128.0
Display Driver 6.14.10.4847 Unknown Compatibility
Sound Device Realtek HD Audio output Pass
Sound Driver 5.10.0.5413 Unknown Compatibility
Operating System Information
Internet Explorer Information
Version 7.00.5730.0013
System Device Information
Processor
Intel -7561.8 Mhz
Memory
System Total 2038.9
Virtual Total 2047.9
Pagefile Total 3934.0
Snapshot
System Available 1545.0
Virtual Available 2007.6
Pagefile Available 3485.6
Monitor Information
Monitor Name Plug and Play Monitor
Refresh Rate 60 Hz
Monitor Information
Refresh Rate 60 Hz
Network Card Information
Name Broadcom 802.11g Network Adapter - Packet Scheduler Miniport
IP Address: KEEP OUT
Subnet Mask: KEEP OUT
Gateway: KEEP OUT
Primary WINS Server N/A
DHCP: KEEP OUT
Background Processes Information
Process Name [System Process]
Process Name System
Process Name smss.exe
Process Name csrss.exe
Process Name winlogon.exe
Process Name services.exe
Process Name lsass.exe
Process Name svchost.exe
Process Name aawservice.exe
Process Name explorer.exe
Process Name aswUpdSv.exe
Process Name ashServ.exe
Process Name spoolsv.exe
Process Name avgwdsvc.exe
Process Name ashDisp.exe
Process Name avgtray.exe
Process Name LManager.exe
Process Name avgfws8.exe
Process Name RTHDCPL.exe
Process Name igfxtray.exe
Process Name hkcmd.exe
Process Name igfxpers.exe
Process Name igfxsrvc.exe
Process Name msmsgs.exe
Process Name TeaTimer.exe
Process Name rundll32.exe
Process Name daemon.exe
Process Name ctfmon.exe
Process Name igfxext.exe
Process Name avgam.exe
Process Name RtkBtMnt.exe
Process Name avgrsx.exe
Process Name avgnsx.exe
Process Name avgemc.exe
Process Name ashMaiSv.exe
Process Name ashWebSv.exe
Process Name alg.exe
Process Name wmiprvse.exe
Process Name firefox.exe
Process Name EasyInfo.exe
Media Device Information
Mass Storage Devices
Type Fixed
File System NTFS
Total Space 69.8 GB
Free Space 42.5 GB
Type Fixed
File System NTFS
Total Space 69.5 GB
Free Space 51.4 GB
Type CD / DVD Drive
File System CDFS
Total Space 588.2 MB
Free Space 0 Bytes
Type CD / DVD Drive
File System UDF
Total Space 4.6 GB
Free Space 0 Bytes
DirectX Information
Version 9.0c
Long Version 4.09.0000.0904
Display Device (Primary Only)
Device
Description Mobile Intel(R) 965 Express Chipset Family
Manufacturer Intel Corporation
GUID D7B78E66-6942-11CF-9573-1E21ACC2CD35
Driver
Version 6.14.10.4847
Module igxprd32.dll
Date 6-22-2007
Memory
Local 256.0
Local 372.5
Non-Local 0.0
Texture 372.5
Sound Device (Primary Only)
Device
Description Realtek HD Audio output
Manufacturer Realtek Semiconductor Corp.
GUID BD6DD71A-3DEB-11D1-B171-00C04FC20001
Driver
Version 5.10.0.5413
Module RtkHDAud.sys
Date 5-11-2007
Capabilities
Max 3D Buffers 33
Supports Mono Output True
Supports Stereo Output True
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
BATTLEFIELD 2 PROBLEM PLEASE HELP AmPdolls Networking and Internet 1 August 27th, 2007 11:07 AM
Battlefield 2 problem TzarBHD General Gaming Discussion 1 October 16th, 2006 07:59 PM
Battlefield 2 problem Del80y Technical Support 0 July 9th, 2006 10:23 AM
Battlefield 2 Problem Pd645 General Tech Discussion 14 May 10th, 2006 07:48 PM
Battlefield 2 Problem JudoCow09 General Gaming Discussion 1 July 18th, 2005 12:23 AM
Is It Just Me? (2907)
3-days in and no threads about Gaza (161)
New Build ( Finally ) (7)
CPU wont boot (7)
Building a gaming computer advice (5)
Folderchat Weekday thread (444)
RCA 52Inch HDTV wont turn on (5)
Upgrading RAM (6)
ACPI controller halt on boot (4)
Futronix has water features? (1)
Laptop proccesor to desktop mob.. (2)
Please help! multiple problems! (4)
Common Spyware Solutions (97)
How do you move a hard-drive to.. (4)
What is the best external enclo.. (0)
Core 2 Quad Q9550 system (3)
