Small window needs enlarging
Currently Active Users: 1584
Discussions: 200,933, Posts: 2,379,175, Members: 246,298
Old June 27th, 2008, 08:39 AM   Digg it!   #1 (permalink)
draboo's Avatar
Send a message via MSN to draboo Send a message via Skype™ to draboo
I am using XP pro on my laptop. Whenever I open up a window,it opens up small,a leftover thing when I was dragging files around from one folder to the next on my mp3 player. Now every time I open a new page ,it always comes up small. Then I have to maximize it.
Is there any way to make windows open up into a full page? or am I stuck with a small window coming up forever??
Thanks,eh?
Brad
"life is short..don't be a dick"
Phyllis Diller
draboo is online now   Reply With Quote
Old June 27th, 2008, 10:58 AM     #2 (permalink)
Windows always save the last state of the window size. make sure you set the size you like before you close it. then it will open the way you want.
aRIfA4 is offline   Reply With Quote
need someone to help me with enlarging photo cableuser Graphic Design and Digital Photography 4 July 5th, 2005 08:22 PM
link to open new small window pinoy87 Webmastering and Programming 5 July 23rd, 2003 04:37 PM
Open in New Window small? consumertalks Technical Support 2 July 23rd, 2003 03:48 AM
IE suddenly "open in new window" is small Bill in SD, CA Applications and Operating Systems 2 March 26th, 2003 10:14 AM
Linux- small window manager Germ Applications and Operating Systems 4 February 10th, 2002 05:02 PM
Is It Just Me? (2878)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (1)
Wireless Televisions. (1)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
