ANOTHER UBV PROBLEM, DIFFERENT SENARIO
Currently Active Users: 2587
Discussions: 201,008, Posts: 2,380,090, Members: 246,374
Old July 10th, 2008, 08:16 PM   Digg it!   #1 (permalink)
HEY GUYS,
I'VE BEEN READING FORUM AFTER FORUM FOR THE LAST WEEK NOW, NONE OF WHICH FITS MY SCENARIO. JUST LIKE EVERYONE ELSE, WHEN I TRY TO BOOT I GET THE FAMOUS UNMOUNTABLE_BOOT_VOLUME SCREEN OF DEATH. I TRIED THE INSTALL CD BUT NEVER GET PAST THE PART WHERE IT SAYS "SETUP IS NOW STARTING WINDOWS", I STILL GET THE BLUE SCREEN. SO NOT WANTING TO BE PATIENT, I BOUGHT A NEW HARD DRIVE ON EBAY THINKING MINE WAS BAD. AFTER INSTALLING THE NEW HARD DRIVE AND INSERTING THE XP CD, I GET THE SAME EXACT UBV BLUE SCREEN. AHHHHH!!!! NEW BLANK HARD DRIVE AND STILL SAME THING! ALSO I RAN THE DIAGNOSTIC PROGRAM BUILT INTO THE BIOS OF MY DELL D600, AND IT GAVE ME A DST ERROR ON THE ORIGINAL HARD DRIVE BUT NOT THE NEW ONE.
I HAVE BEEN READING A LOT ABOUT THIS AND READ SOME KIND OF 40 TO 80 PIN PROBLEM....
SOMEONE PLEASE HELP!!!!!
jlthompsonn is offline   Reply With Quote
Old July 10th, 2008, 08:59 PM     #2 (permalink)
BipolarBill's Avatar
Welcome to TechIMO!
First, please stop with the CAPS. It makes you seem to be yelling, which could be seen as rude.
At what exact point does this error show up? There are two distinct phases when setting up Windows. There is the first part where you select the drive and install the files and then there's phase two where the PC restarts and Windows tries to actually start by itself.
Phase one or two?
Do you have a SATA drive?
Do you have a special card that your hard drive is connected to?
Is the new drive set up as drive 1 or Master?
Did you remove the old drive or just add the new one to the mix?
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
Old July 11th, 2008, 08:52 AM     #3 (permalink)
Sorry about the CAPS.
The UBV Blue screen appears just after setup loads drivers and setup files. Says Setup Is Starting Windows, then UBV Blue Screen.
It is not an SATA Drive.
The laptop is a Dell D600, here are the specs on the hard drive:
Specifications:
·Manufacturer – Hitachi
·Part Number: 08K0852
·Rotational Speed – 4200 RPM
·Capacity – 40GB
·Interface – ATA/IDE
·Form factor width - 2.5”
·Form factor height – 9.5MM
·System Type – Laptop, Notebook
it is the only drive in the computer.
Any Suggestions?
Old July 11th, 2008, 09:38 AM     #4 (permalink)
Just to be perfectly clear, this is happening before the point where you press F8 to accept the legal agreement?
Do you ever get to see the hard drive partitions and choose a place to install?
Old July 11th, 2008, 05:59 PM     #5 (permalink)
On the original hard drive I can get passed the f8 screen where it shows Windows XP Copy Write and the little bar that scrolls across the screen, about 5 seconds into it is when I get the UBV screen.
But to answer your question, I cannot get to the part where it asks to hit f8 to accept agreement.
I've tried every f8 boot option, neither of which works.
New hard drive doesn't make it that far of course because it is blank.
I cannot get to the screen that shows partitions on either drive, even when I try install disc on original hard drive. (but, original hard drive has Windows XP Home and the install cd I am using is XP Pro.)
Old July 11th, 2008, 06:16 PM     #6 (permalink)
THE Gimp Clown Fish!
nemowolf's Avatar
Formated or not, a new drive should have no problem getting passed the F8 to accept the license. This sounds like you have a controler problem. I am also going to assume that this is out of warranty since your asking here. You may need to try both your old and new hard drive in another system to ensure they are not the cause of the problem. IF they test fine, then your Mobo is bad and is not reading/writing the information from/to your drive properly I would gather.
Old July 11th, 2008, 06:26 PM     #7 (permalink)
I hope that this Pro "upgrade" CD is genuine. A badly copied CD would cause this problem.
Old July 12th, 2008, 04:06 PM     #8 (permalink)
Unmountable Boot Volume
talks about a 40-wire cable and 80-wire UDMA... my hard drive does have an adapter.... think that could be it?
Old July 12th, 2008, 08:21 PM     #9 (permalink)
What type of adapter?
Computer Problem out of the blue...(long post explaing problem) Aegaeonos General Tech Discussion 3 December 21st, 2006 05:37 PM
UBV, an even bigger problem! (Unmountable Boot Volume) Kahn_Tayel Technical Support 5 March 16th, 2004 01:16 AM
IE Save picture problem/Real player problem smkeller9 Technical Support 3 February 22nd, 2004 03:42 PM
Memory problem after format & partion problem soulja Technical Support 3 June 2nd, 2003 10:59 PM
Irritating Problem With Windows Media Player 9 Series, and TV-OUT Problem. HELP! ₯ KOMI ₯ Graphics Cards and Displays 2 November 15th, 2002 05:03 PM
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
