Dell Dimension E521 power supply?
Currently Active Users: 2591
Discussions: 203,415, Posts: 2,407,361, Members: 248,939
Old July 21st, 2008, 12:00 PM   Digg it!   #1 (permalink)
Exclamation
I have a Dell Dimension E521 running an AMD 4200+ processor in it. I just purchased a ATI Radeon HD4850 graphics card I am going to install in it this week. I have a few questions related to this...
1. The current Dell power supply is 305W, will that handle the extra power the video card will be pulling, or do I need to upgrade the power supply?
2. If I need to upgrade the power supply, can someone recommend a power supply that will work with the Dell Dimension E521 and power the extra power from the video card? (I would prefer to purchase a new power supply from NewEgg is they carry one that will work.)
3. If the current power supply MIGHT handle the extra power being pulled by the video card, is there a danger in 'testing' it to see if it will work? In other words, what actually happens if the power supply isn't able to provide enough power to the computer? (Hoping for it just doesn't work, rather than burning up in flames.
Thanks!
markothegreat is offline   Reply With Quote
Old July 21st, 2008, 12:48 PM     #2 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
The Power Supply probably won't handle the new card.
So, I would get a new Power Supply, such as an OCZ 600 watt, which sells for around $80.
Let me make sure the Power Supply will fit the Dell.
Edit- While I'm not totally positive, I'm reasonably sure the OCZ will fit in the Dell.
If someone could confirm this, it would be appreciated.
Here's the OCZ line-
Newegg.com - OCZ StealthXStream OCZ600SXS 600W ATX12V / EPS12V Power Supply 100 - 240 V CB, CE, CSA, UL, FCC - Power Supplies
http://www.ubuntu.com
Old July 21st, 2008, 01:54 PM     #3 (permalink)
And is there an danger to try it on my current power supply? Assuming it has all the right power connectors.
Old July 21st, 2008, 02:09 PM     #4 (permalink)
Ride 'em Cowboy
Shouldn't be any danger....If you don't have enought power - it won't boot up.
Have you hugged your kid today??
Steve R Jones is online now   Reply With Quote
Old July 22nd, 2008, 09:29 PM     #5 (permalink)
Okay, so now I got the power supply recommended above and have installed it. However, it is not booting. The power is working as the power light, motherboard light, etc, all come on, but no CPU, harddrive, fan on the power supply etc. Any thoughts on what this might be? Is it something specific to the Dell motherboards?
Old July 22nd, 2008, 10:37 PM     #6 (permalink)
ATI 4850 FTW!
#43 fan's Avatar
Are sure it is plugged in properly in the motherboard and all the peripherals?
Old July 22nd, 2008, 11:06 PM     #7 (permalink)
voids warrantys
KarmaKiller's Avatar
Double check that the new GPU is plugged in too.
(Had to mention it, sorry)
Q6600@4Ghz | I7 920@4.3Ghz | E6320@3.5Ghz
FAQ's ~ Team Stats
My PC
Old July 29th, 2008, 02:14 PM     #8 (permalink)
Diamond 4850 and Dell E521 305W PSU
I installed Diamond 4850 in my Dell E521(HD4850, X2 4200+, 4x1G 667MHz DDR2, 2 SATA drives, no DVD/CD drive, stock 305W PSU)
Everything looks good so far, and I also ran 3DMark2006 without any issue.
BTW, I made the 4pin molex to PCIe power adapter myself.
The stock PSU may be not powerful enough for 4850, so do this at my/your own risk
Jeff
wujiafu is offline   Reply With Quote
Old May 6th, 2009, 08:18 AM     #9 (permalink)
Did you get your new power supply to work last year?
I'm interested to find out if you got your PSU to work last year. I'm thinking of a similar upgrade to do in my E521.
Thank you
trwagner1 is offline   Reply With Quote
Old May 6th, 2009, 09:40 AM     #10 (permalink)
Big_Daddy's Avatar
Try a 4670. It doesn't pull much power
Swan XT10 640K 20M HD Hercules Graphics
Big_Daddy is offline   Reply With Quote
Dell Dimension E510/5150 Power Supply Upgrade?? ket820 Motherboards 8 April 22nd, 2009 07:56 PM
Power supply for Dell MattJ Graphics Cards and Displays 26 December 31st, 2007 05:57 PM
Looking for replacement power supply for dell dimension 4700 snsowens Technical Support 10 September 2nd, 2007 07:13 PM
Dell Laptop Power Supply PakCafe Technical Support 4 August 13th, 2005 09:01 AM
Dell Power Supply win2kuser General Tech Discussion 7 August 22nd, 2003 03:53 AM
Is It Just Me? (3716)
nVIDIA GTX 260 vs ATI 5770 (5)
Superbowl commercials (The green po.. (15)
and she wanted to be VP? (42)
GPU upgrade from 8600 GT (11)
New PC Heavy Gaming Rig (8)
[F@H Chat]2/6/10 New thread for ya'.. (22)
Need for Speed Shift (7)
Best route for upgrade (several opt.. (5)
Motherboards with 2 PCIE x16 slots (8)
Graphene transistors promise 100GHz.. (7)
I want to buid a pc with this case (14)
Animated GIFs don't animate? (13)
Upgrading (5)
Microsoft Wireless Keyboard 3000 (13)
Laptop - HDTV Connection Using HDMI C.. (2)
How Good is This $450 MSI Laptop? (3)
HD5870 Question (16)
[F@H Chat]2/6/10 New thread for ya' s.. (22)
Wireless G printer w/wrt160n (0)
SpeedFan Temp Monitor Help (3)
BSOD - IRQL not less or equal - HELP! (0)
Unable to find LAN (7)
Best route for upgrade (several optio.. (5)
should i upgrade whole pc or just vid.. (2)
WEBCAM / XP / XP64 / VISTA (7)
routers and switches OPERATING SYSTEM.. (0)
One dumb nube and a cisco 3550 (1)
120mm fan on top of case??? (12)
Is my hard drive going bad? Please h.. (2)
rsync over passwordless ssh in a cron.. (4)
Wii at buy.com for $374 - Carnival Sm.. (7)
Deleted email addy keeps bouncing bac.. (1)
Video Format Total Solution: How to C.. (0)
wireless connectivity (0)
