May 7th, 2002, 08:54 PM #1
Enermax fans with the speed control Q---
I have a few of these, it has a separate dualwire with a speedcontrol pot on it, how can I eliminate the speed control locking the fan at its max speed, simply cut the control off---or connect the speedcontrol ends ends eliminating the pot? I guess I could experiment wildly, just wondering if anyone can provide a clue before I start cutting wires...
Here is what the speed dial looks like:
May 7th, 2002, 09:14 PM #2
Isn't the pot just a resistor? If you take it out of the circuit, you should be 100% all the time.
-Whir
May 7th, 2002, 09:36 PM #3
Yes, just hotwire it together.... I think.
Thats a potentiometer, three wires. I do believe you just hotwire it.
May 7th, 2002, 09:59 PM #4
You can test the theory by baring a little of each wire going to the speed control pot and shorting them together, this would bypass the speed control temporarily without doing anything permanent.
Gastroparesis is a medical condition in which nerve or muscle gets damaged in the stomach that causes slow digestion and emptying, vomiting, nausea, or bloating. Quick Facts Also called...
Trenical for Gastroparesis...
