Join TechIMO for Free!
Thread Tools
Currently Active Users: 1829
Discussions: 188,402, Posts: 2,243,616, Members: 232,634
Old August 4th, 2008, 08:33 AM   Digg it!   #1 (permalink)
Calculating KVA/MAX
Hi there.
I am a total noob when it comes to math.
Can somebody please tell me how I can calculate Kilo Volt Ampere?
I have 230 V
I have 10 A
I have 2300 W
How can I get this to Kilo Volt Ampere??
Can anyone help me plz....
Yours truly
Johndoemalle
johndoemalle is offline   Reply With Quote
Old August 4th, 2008, 09:30 AM     #2 (permalink)
Send a message via AIM to etnietering
Calculating Volt-Amps can be very tricky, as it deals with the capacitance/inductance of the load. Here is a link that will hopefully help you out: Power factor - Wikipedia, the free encyclopedia
etnietering is offline   Reply With Quote
Old August 5th, 2008, 01:27 AM     #3 (permalink)
KVA Calculation
It's actually quite easy assuming single phase wiring.
VOLTS x AMPERES = KILOVOLT-AMPERES (kVA)
1000
So.... 230 VOLTS x 10 AMPERES = 2300 VA
2300 VA \ 1000 = 2.3 kVA
Hope that helps.
btw, if it is Three Phase power use this....
VOLTS x AMPERES x 1.73 = KILOVOLT-AMPERES (kVA)
1000
AWCables is offline   Reply With Quote
Old August 5th, 2008, 05:10 AM     #4 (permalink)
1000
Hope that helps.
1000
Hi there.
Volt * Ampere gives WATT.. not VA.... :S
Damn i an stupid when it comes to this
Old August 5th, 2008, 05:11 AM     #5 (permalink)
hi there..
I have been reading this and still nothing :S
Old August 9th, 2008, 09:51 PM     #6 (permalink)
VA vs. WATTS
VOLTS x AMPS = WATTS in DC, however in AC the volts and amps are not exactly in phase and WATTS needs to be calculated by multiplying the VOLTS X AMPS and then take the average over time. The ratio between the VA (i.e. rms volts times rms amps) and Watts is called the power factor PF.
VA X PF = Watts (any load, including inductive loads)
For resistive loads VA and WATTS in AC are nearly identical.
Regardless the formula to calc your Kva is correct
Old November 22nd, 2008, 10:05 AM     #7 (permalink)
33kva
hi,
33kva how much takes total amps
narayana
vinod264 is offline   Reply With Quote
Old November 22nd, 2008, 10:13 AM     #8 (permalink)
33kva
hi,
narayana
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Early calculating tools no1_vern IMO Community 0 January 26th, 2008 06:02 AM
Calculating Power Consumption & Green Savings SiliconJon General Tech Discussion 6 January 17th, 2008 02:22 PM
Calculating Power Consumption ShaunTaylor18 General Tech Discussion 3 September 24th, 2006 02:14 PM
compound intrest... and calculating it for different rates ShuckyD Webmastering and Programming 32 October 19th, 2005 03:30 PM
C++ calculating standard deviation Elburn Webmastering and Programming 30 March 18th, 2004 07:16 PM
Is It Just Me? (2908)
3-days in and no threads about Gaza (161)
New Build ( Finally ) (7)
CPU wont boot (7)
Building a gaming computer advice (5)
Folderchat Weekday thread (444)
RCA 52Inch HDTV wont turn on (5)
Upgrading RAM (6)
ACPI controller halt on boot (4)
Futronix has water features? (1)
Laptop proccesor to desktop mob.. (2)
Please help! multiple problems! (4)
Common Spyware Solutions (97)
How do you move a hard-drive to.. (4)
What is the best external enclo.. (0)
Core 2 Quad Q9550 system (3)
