August 27th, 2008, 11:00 PM
| Junior Member
| Very n00b question about led
So sorry about the n00b question. When it comes to conversion, my brain freezes.
To make this simply, heres what i want to do....
I want to take this led bulb ( Besthongkong - Eastern LED Source Shop: Loose LED, High Power LED, Car Auto LED, LED Light Bulbs, LED Strips, LED Flashlight, LED Module 100mA 10mm High Power White 10mm LED 55 Degree) and put it on a 12V line by itself. It will not daisy chain to another led bulb. What resistor do i need to MAXIMIZE its brightness. 100ohm or the 470ohm.
My goal is to replace my landscape low voltage bulb with these. Possible?
the specs of the bulb...
High Power 20-100mA 5 chips White 10mm LED
* Vf: Typ 3.3V
* Iv: 10000-18000mcd @ 100mA, Total power 825,000mcd*
* Iv: 20lm @ 100mA Max, 1W power ~53lm*
* Viewing Angle: 55 Degree
* Color : Pure White
* Super Reliable LED, 14 MIL chips.
Many thxs!!! |
