September 9th, 2008, 07:00 PM
| memory upgrade problem
I have a Dell Inspiron 8600. I installed 2 memory sticks ( 1 gig each). When I install the first stick eveything works fine. When I install the 2nd gig in the "B" slot. the computer works for about a minute then it does a memory dump. Right now i'm using only the one gig. I've tried using other manufacturers memory and it still does a dump. Help !!! |
September 10th, 2008, 06:17 AM
What happens when you put a chip only in slot B? |
September 10th, 2008, 09:51 AM
the same thing, another dump. Someone told me that I might be able to change BIOS. Thought that might be dangerous. |
September 10th, 2008, 10:48 AM
Maybe slot B is bad...Do still have the original ram and can test it in slot B? |
September 10th, 2008, 11:27 AM
put original chip in slot B and it did an immediate memory dump. |
September 10th, 2008, 11:38 AM
| | ATI 4850 FTW!
| Quote:
Originally Posted by postalpete put original chip in slot B and it did an immediate memory dump. | Sounds like a bad slot. |
September 10th, 2008, 11:57 AM
Is it worth replacing the slot ? laptop is over 3 yrs. old. |
September 10th, 2008, 12:06 PM
Depends on how much the repair costs...It's attached to the mobo and the problem could be there. |
September 10th, 2008, 12:20 PM
keep it 1 gig for awhile, get a new laptop probably cheaper in long run. |
| You may post new threads You may post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Memory Upgrade | wizzer | Processors, Memory, and Overclocking | 6 | December 22nd, 2007 12:59 AM | | MEMORY UPGRADE | BoomShaker | Processors, Memory, and Overclocking | 4 | September 16th, 2006 06:22 PM | | Memory Upgrade Problem | jagee | Processors, Memory, and Overclocking | 6 | April 18th, 2006 12:31 PM | | Memory Upgrade | waynezo | General Tech Discussion | 1 | May 10th, 2004 10:14 AM | | Memory Upgrade | chefde | Technical Support | 6 | December 30th, 2001 11:56 AM | | Most Active Discussions | | | | | Recent Discussions  | | | | | |
