HELP.
I have a K7SOM Mobo with a Graficcard onBoard.
I tried to install the 3DProphet 2 MX from Hercules under Windows2K. First it startet in the standard VGA-Mode with no Probs. After i'd install the Hercules drivers successfully and i'd reboot the system, windows2k hangs up at the loading screen!
Isn't that card running with Win2K ???
What Geforce card (PCI) i can use with this MOBO ???
Pls help !!!
Hi,
I have the same problem now with same MB but dif card, XFX Geforce2 .... same problem on XP .... as soon as it starts loading and when I should chose the user .... couple of blue flashes and nothing... could b the BIOS?
Well the problem is that this BIOS and MB dont allow to disable the onboard video... they say... well then you can use two monitors.... yeah right... If u can make them work!
But the question is: a BIOS issue can stop XP loading in the middle of the process? or should happen as soon as the machine boots?
