Are your drivers all installed? What kind of a computer is it? Is it a boxed computer or a home build? If its a Dell, HP, Compaq, Gateway, etc. you should have had restore discs that automatically installed the drivers needed for that model. For something that was a "whitebox" or home build you need to install the drivers that either came with your network card or your motherboard (for onboard LAN)
