Join TechIMO for Free!
Thread Tools
Currently Active Users: 2362
Discussions: 186,582, Posts: 2,226,763, Members: 230,209
Old October 10th, 2008, 11:23 PM   Digg it!   #1 (permalink)
s1m
Problem With IDE Hard Drive
My First Computer was dropped on it's head. Decided not to work anymore.
So I took everything out cd rom drives Mobo and including Hard Drive.
I bought a new computer and now i want to make the IDE hard drive a slave for my new comp.
My new comp has a SATA drive as a master when I plug in my 160gb IDE Hard Drive as a slave and turn my computer on the 160GB IDE HardDrive Screams and Whines... like a weak reving engine. VROOOOM VROOOOOOOOOOM VROOOOOOOOM VROOOOOOOM VROOOOOOOM when I get to my login screen the VROOOM completely stops and there is no vibration what so ever from the Hard Drive.
Is there something I'm doing wrong? I have extremely important files on this Hard Drive and I have no clue what to do at this point.
s1m is offline   Reply With Quote
FREE instant scan
Old October 11th, 2008, 02:32 AM     #2 (permalink)
for SATA drives there is no master/slave configuration, its one device per cable, not like IDE that can have 2 per channel.
well for starters you bought a new computer, & the "master" drive is the SATA drive, THAT is the drive that the system loads up off of, as to the your old drive making the sounds & then stopping, the system is probably running it with the Power On Self Tests, then since it doesn't need to load windows or whatever OS your running off of it & just off the newer drive, there's no reason for the drive to be running, so it stops.
its also possible the drive is FUBAR... you said your old computer was dropped on its head, if you mean literally, then its possible the hard drives heads are out of whack & make it damn near impossible for you to get any data off the drive, unless you know how to fix the things your self, or can send it in to a data recovery service to get the data, which is DAMNED expensive to do.
Do you also hear a loud clicking sound when the old drive is being accessed? if so, start praying...
Old October 11th, 2008, 02:48 AM     #3 (permalink)
s1m
Thanks for the fast reply....
no clicking just screaming and whining, i was playing around with it some more, I set it as a master and waited for the pc to load it. My bios detected it but only like 8000mb. Something is wrong.. atm i'm trying to find bootable software that can get as much data off my drive as possible.
Old October 11th, 2008, 05:35 AM     #4 (permalink)
Cool
some dll files may be missing its your os problem and clear prefetch folder in system32 which makes login late
karthiktech is offline   Reply With Quote
Old October 11th, 2008, 06:01 AM     #5 (permalink)
WTF are you even talking about?
Old October 11th, 2008, 09:58 AM     #6 (permalink)
If the new drive is SATA and the old is IDE, why would the old drive be set up as a slave? Isn't the old drive on the IDE channel alone? If so shouldn't it be set up in master mode? Anyway, it does sound like the drive is fubar, you might find a diagnostic program to make sure. Does the drive and MB support SMART, if so what does it say?
Cajunheat is offline   Reply With Quote
Old October 11th, 2008, 05:23 PM     #7 (permalink)
DoctorReno's Avatar
If you can, try getting your hands on the ultimate HD checking program called SpinRite. It will give you a definitive answer on the condition of the IDE drive, any HD for that matter. If the drive never made the noises before the accident I'd be a little worried. Good luck. Keep us updated on how things go.
If you can't say something nice... SAY IT REALLY LOUD!!
DoctorReno is offline   Reply With Quote
Old October 11th, 2008, 07:59 PM     #8 (permalink)
Nude_Lewd_Man's Avatar
Send a message via MSN to Nude_Lewd_Man Send a message via Skype™ to Nude_Lewd_Man
:r ofl:
Whenever someone says "You can't miss it" I invariably do...
Nude_Lewd_Man is offline   Reply With Quote
Old October 11th, 2008, 08:02 PM     #9 (permalink)
When you go into the OS, what does it display in there - both in terms of size and also data on the drive..................?
If you can see data then copy as much as possible elsewhere, otherwise you will need to go back to your backups.....
EDIT: I'm presuming that it is backed up, especially if it is important data....
Old October 11th, 2008, 08:04 PM     #10 (permalink)
Wow, I edited but it didn't show up...
Or have I been drinking too mch again./?
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Hard drive and DVD Drive, only 1 IDE mrhelloo Storage Related 1 July 18th, 2007 05:22 PM
Hard Drive Performance SATA or IDE muarrif Storage Related 25 June 23rd, 2005 11:00 AM
Sata and IDE Hard drive generallee5686 Storage Related 11 December 30th, 2004 12:17 PM
SATA and IDE hard drive question lefty31199 Storage Related 14 October 25th, 2004 06:05 PM
Any IDE hard drive recomendations pbharris Storage Related 9 December 5th, 2001 01:26 AM
Is It Just Me? (474)
Why Does the MOON Grow Bigger as It.. (5)
Happy Birthday Atomic Rooster (9)
Connected to LAN but unable to use .. (5)
1 internet. 1 house. 3 computer. ho.. (7)
Multiple video cards? (6)
old photos and files from e mac.. (2)
SSD's, RAID, and External Backu.. (3)
Folderchat: The Holiday thread (108)
Need to retrieve files from a v.. (1)
C++ compiler suggestions (0)
no power up (1)
3d "effects" (4)
HD TV Reccomendations (7)
What do i need to get SSD drive.. (14)
