Flashing power LED
Currently Active Users: 2581
Discussions: 201,008, Posts: 2,380,090, Members: 246,374
Old November 20th, 2008, 11:19 PM   Digg it!   #1 (permalink)
Flashing power LED
I am building a computer. I installed an ECS GeForce 7050M-M motherboard, an AMD Athlon 1620 CPU, 4 Gb of PC3200 ram and a 550 watt power supply.
(I have assembled several recently with this -- or a similar -- configuration.
When I turned on the power, CPU fan came on but the power led flashed rather than stayed on. HD power light did not come on. System did not boot.
I have not seen this one before. What do I check now?
RDSmith0 is offline   Reply With Quote
Old November 21st, 2008, 06:17 AM     #2 (permalink)
BipolarBill's Avatar
This is a pretty standard "PC will not boot" issue. There are tons of similar posts about it.
You need to bench test the motherboard outside of the case. Remove the board from the case, place it on a soft, non-conductive surface near the case and plug in the ATX power. Leave in the CPU and RAM. Place the vid card in and connect the monitor. Connect the power. Nothing else needs to be connected. Press down hard on the vid card and use your screwdriver to short the POWER BUTTON pins. See if it POSTs.
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
I have a flashing power LED on my WRT54GP2 Sneblot Networking and Internet 1 November 18th, 2008 06:48 PM
Power LED wrong size n MB dzee Motherboards 11 May 19th, 2005 11:43 PM
490CTD dead-flashing power light exbrit Technical Support 3 October 11th, 2004 05:06 PM
Power led doesn't work dewitn Motherboards 5 August 6th, 2004 11:13 PM
Need to replace hdd and power LED. OC Guy PC Modification 4 September 29th, 2002 06:53 PM
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
