Join TechIMO for Free!
Thread Tools
Currently Active Users: 1911
Discussions: 188,402, Posts: 2,243,617, Members: 232,634
Old December 4th, 2008, 11:55 PM   Digg it!   #1 (permalink)
Box alive but monitor dead
Hello,
I built my first system ~6wks ago it was loads of fun. It worked great for about 4wks (just past the 30day warranty), but suddenly it completely stopped powering up (no fans, no beeps, no PSU fan, etc) I assumed it to be a failed PSU, but upon replacing the PSU, no change. So, after running down a few "troublshooting" lists I replaced the MoB which appears to have been the problem. (I should also mention that during the "fix" my montor was dropped..oops)
The good news is that it now powers up, everything sounds and looks good (fans, LEDs, HD, etc) EXCEPT the monitor won't do anything. The monitor is a nice shinny new 22 LCD that looks REAL sweet when run off another computer, but it has "no source" when connected to my running computer.
I first attempted to run the monitor off my new MoB or my video card, but no luck with either. I tried running it off the system after I removed the video card, but still no luck. I figure it can't be a driver problem with absolutely no life in the monitor. It also isn't the cable or the monitor (both work with other systems).
FYI: Here is the system (was running Ubuntu Ibex):
Acer X223Wbd Black 22"
MSI NX8600GT Twin Turbo GeForce 8600 GT 256MB
CORSAIR 4GB (2 x 2GB)
Western Digital Caviar GP WD5000AACS 500GB
SAMSUNG 22X DVD±R DVD Burner
APEVIA Black 500W ATX Media Center / HTPC Case
AMD Athlon 64 X2 5400+ Brisbane 2.8GHz
Foxconn A7GM-S AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
I really hope it isn't my new motherboard having problems. Any help would be appreciated.
jovial is offline   Reply With Quote
Old December 5th, 2008, 10:32 AM     #2 (permalink)
BipolarBill's Avatar
How can you be so sure that the PC is working correctly when you can't "see" what's happening?
1. Is the hard drive LED flashing?
2. Do you hear the Windows welcome sound from the speakers?
If the answer is no to either question, assume it's the PC.
My guess is that you bought a weak or defective power supply because you didn't mention what you got.
MCSE, MCP, MVP and nut job
BipolarBill is online now   Reply With Quote
Old December 5th, 2008, 11:01 AM     #3 (permalink)
Thanks for the quick reply. I love your icon. I have two PSU's but I am currently running the 500W standard that came with the case. However, I also have a 650W (COOLER MASTER Real Power Pro RS-650-ACAA-A1 650W) that I'll try when I get home. As for the sound, I'm running Ubuntu Ibex, but I'll try hooking up some speakers. I'm concerned that it isn't the PSU because it is a 500W and the HD sounds great on startup, all the right spinning sounds. Also, the DVD player opens up great and spins up nicely (by sound alone) when a DVD is inserted. I'll let you know what happens but if any one else has any other ideas, let me know. Thanks!
Old December 5th, 2008, 01:07 PM     #4 (permalink)
Just be sure that the hard drive LED is actually flickering.
Old December 5th, 2008, 05:30 PM     #5 (permalink)
I tried changing out the PSU...no change. Any other suggestions.
BTW, what do you mean by the HD LED flickering? My HD doesn't have an LED.
Thanks again.
Old December 6th, 2008, 03:41 AM     #6 (permalink)
Fizur2002's Avatar
have you tried hooking your monitor into a different port on your video card? When you first start up the computer, can you even see the post screen display or is it just when you start going into the startup process for linux? Also, try hooking your monitor into the motherboard video port and see if you can get display that way as well.
Originally Posted by pullmyfoot View Post
Aha. Well that was a waste of time I feel quite stupid now
Originally Posted by Figgey View Post
CPU: AMD 64 Pentium 4 (939 Socket)
Originally Posted by strjms72 View Post
Craysis is more better than COD 4.
Fizur2002 is offline   Reply With Quote
Old December 6th, 2008, 03:33 PM     #7 (permalink)
Still nothing.
I had tried all different ports (MoB and video card) no luck.
The screen is entirely dead. Ie. had "no input". So I never see anything from the computer on the screen.
Hummmmmmmm
Old December 8th, 2008, 07:51 PM     #8 (permalink)
I've decided to send back the MoB for a replacement. If a replacement doesn't work all that is left is the CPU....I think.
Old December 8th, 2008, 07:55 PM     #9 (permalink)
Fizur2002's Avatar
did you get any post codes at all?
Old December 19th, 2008, 08:43 AM     #10 (permalink)
Sorry about the delay. I returned the MoB for replacement, but there is no change with the new MoB.
I figure since I am getting no post codes the CPU must be the problem. Time to find a new CPU
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Dead, yet alive, power supply... Slashero Technical Support 12 January 16th, 2008 02:21 PM
Dead or Alive 4 (Xbox 360) Review RobRich Game News Discussion 12 February 14th, 2006 05:01 PM
Osama dead or alive? Epidemic IMO Community 42 November 1st, 2004 09:29 AM
Zarqawi: Dead, Alive, Fabrication? ClubMed IMO Community 3 June 30th, 2004 08:10 AM
O B L Alive or dead Epidemic IMO Community 0 April 22nd, 2002 08:50 PM
Is It Just Me? (2909)
3-days in and no threads about Gaza (161)
New Build ( Finally ) (7)
CPU wont boot (7)
Building a gaming computer advice (5)
Folderchat Weekday thread (444)
RCA 52Inch HDTV wont turn on (5)
Upgrading RAM (6)
ACPI controller halt on boot (4)
Futronix has water features? (1)
Laptop proccesor to desktop mob.. (2)
Please help! multiple problems! (4)
Common Spyware Solutions (97)
How do you move a hard-drive to.. (4)
What is the best external enclo.. (0)
Core 2 Quad Q9550 system (3)
