Samsung 52A650 Volume issue
Currently Active Users: 1720
Discussions: 200,957, Posts: 2,379,500, Members: 246,327
Old January 4th, 2009, 07:54 AM   Digg it!   #1 (permalink)
I set up my Samsung 52A650 and have a problem. I set my cable box (Scientifica Atlanta Explorer 8300HD) remote to accept the Samsung, and everything but the volume works fine. When I try to increase or decrease the volume either through the remote or from the box itself, the volume icons appear and go up or down when the volume button is pressed, but the volume stays the same. I can program the remote to bypass the cable box volume and use the TV unit volume, but you have to click the volume button for each increment of volume. So, instead of taking two seconds to go from zero volume to 80, by holding the volume button down, I have to click it 80 times, which is very annoying. So, my question is, how do I get the volume on the cable box to work?
mrzoso68 is offline   Reply With Quote
Old January 4th, 2009, 08:36 AM     #2 (permalink)
Send a message via Skype™ to mbzn
Go to "control panel/sound" change the default sound device to the one you use to to output.
sometimes two show up and the volume control only works with the default one.
mbzn is offline   Reply With Quote
Samsung Driver Issue NoJabbaNoBogRoll Storage Related 11 June 11th, 2008 01:17 AM
Volume Issue jj52786 Multimedia and Audio 3 June 5th, 2005 01:11 AM
Samsung 172X va Samsung 710T Dribbles Graphics Cards and Displays 4 October 23rd, 2004 01:54 PM
Volume issue when playing DVDs whip_cracker Technical Support 7 October 12th, 2004 12:35 AM
Small volume issue Cook_1 Technical Support 2 August 3rd, 2004 12:24 AM
Is It Just Me? (2950)
Print spooler problem (15)
Open With ..... Win7 (1)
Kingston Bluetooth Dongle Driver (0)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
