Ford Mondeo Power Steering
Currently Active Users: 2610
Discussions: 201,007, Posts: 2,380,083, Members: 246,373
Old January 5th, 2009, 01:09 PM   Digg it!   #1 (permalink)
I put some water in the power steering reservoir by mistake but the engine hasn't been on since then, and I syphoned the fluid and water out a few hours after the accident. I was wondering if syphoning alone would have removed all the water present in the reservoir, or would i have to bleed the hoses that connect to the pump also too. And also, I bought some PS Fluid from Halfords (their own brand) and I was wondering if is alright to use, because on my car manual it says you need WSA-M2C 195-A.
zobo75 is offline   Reply With Quote
Old January 5th, 2009, 01:24 PM     #2 (permalink)
you did whatto your car?
ok, MY first reaction would be the same.
I'm not a specialist in this matter, but to be on the safe side I'd bleed the hoses.
Also I don't think it'll be a problem to use the fluid from halfords.
Brands always tell you to use their own stuff. while other stuff works as well.
fraksken is offline   Reply With Quote
Old January 5th, 2009, 01:24 PM     #3 (permalink)
Anime Otaku
RobRich's Avatar
Welcome to TechIMO!
I suggest taking it for a power steering system fluid flush.
About fluid type, AFAIK, Ford used to suggest using Mercon spec automatic transmission fluid to top off power steering for many of its models. However, if you want to go that route, call the parts department at your local Ford dealer to make sure it is compatible with your specific model.
Robert Richmond | TechIMO Community Relations Director
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is offline   Reply With Quote
What causes loose steering? Bizkitkid2001 IMO Community 9 April 24th, 2005 08:13 PM
NFSU Steering Wheel SiLVerBuRn General Gaming Discussion 3 August 7th, 2004 11:43 AM
Steering Wheel Questions JayMan General Gaming Discussion 3 September 11th, 2003 08:57 AM
My New Wingman steering wheel soulja Technical Support 2 August 22nd, 2003 10:58 AM
Toyota better than Ford...so says Ford. OuTpaTienT IMO Community 23 February 19th, 2003 02:12 AM
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Need idiot-proof help for building a .. (1)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
