Need help removing my front usb port (step by step)
Currently Active Users: 2595
Discussions: 200,520, Posts: 2,374,494, Members: 245,842
Old January 5th, 2009, 08:24 PM   Digg it!   #1 (permalink)
I have a Dell Dimension 5100 but my computer wouldnt turn on one day. I noticed that the power button blinked amber for a second. I started checking around the computer and noticed the front usb ports all jumbled and broken. After checking around I noticed a lot of the same problems. I was wondering how I could go about removing / disabling the front usb port.
mrpayne99 is offline   Reply With Quote
Old January 6th, 2009, 05:51 PM     #2 (permalink)
bigBonehead's Avatar
Must be the MAD BASHER at work.
If yer OK with goin into the box, you can dis-connect the USB cable where it connects @ the board...
bigBonehead is offline   Reply With Quote
Old January 7th, 2009, 09:08 PM     #3 (permalink)
Send a message via AIM to yamanx Send a message via MSN to yamanx
Or if you didn't wanna open the case up, you should be able to disable through Device Manager.
2.8Ghz Celeron D OCed to 3.4
4GB RAM
Sapphire HD3650
yamanx is offline   Reply With Quote
Old January 8th, 2009, 01:07 AM     #4 (permalink)
Hmmm... and how would one do that?
Wisdom comes with age, but sometimes age comes alone...
Old May 15th, 2009, 03:38 AM     #5 (permalink)
Disable the front USB ports
How do i disable the front USB ports for a user
Giritharan is offline   Reply With Quote
Old May 15th, 2009, 04:11 AM     #6 (permalink)
glendalf81's Avatar
to disable the front usb ports you will need to go into the device manager and somewhere near the bottom it will list usb controllers, you need to determine which ones are the front ones by disabling 1 at a time and testing each usb port at the same time to find out which one you have disabled and once you have disabled a front one leave it disabled and find the next one
E6550/4gbDDR667/gts250/WD320/WD250/win7ultimate
glendalf81 is offline   Reply With Quote
I need step by step to write zero without downloading willandkj Technical Support 7 November 7th, 2006 09:55 PM
Need a Step by step instruction for setting up a Web Server. Urban_Squrill Technical Support 3 September 23rd, 2003 06:52 PM
Step by step playlist creation using windows media player--- thekingofpain Multimedia and Audio 4 July 25th, 2003 11:15 PM
Step-by-step guide for Linux wanted FieldDoc Applications and Operating Systems 2 April 29th, 2003 01:35 AM
Is It Just Me? (1658)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
[F@H SPAM 11/1/09]New month . . . n.. (34)
slaving laptop drive (7)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
[F@H SPAM 11/08/09] Where has all the.. (0)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
