New 22" Widescreen Monitor Stuck on 1280x960...Please Help :)
Currently Active Users: 2649
Discussions: 200,966, Posts: 2,379,629, Members: 246,332
Old January 26th, 2009, 06:54 PM   Digg it!   #1 (permalink)
Hello there, a newbie...my first post so forgive me if this question has been answered before..did a search but didnt find a solution..
Okay here we go..
Just bought a Nice Acer P223W .... its a beauty for what I got her for but there is an issue..
Tech Specs...
Display Adapter - Nvidia GForce FX5200 (128Mb DDR, 8xAGP, DVI and VGA Out)
PC SPEC - Here The Link
BIOSTAR
RAM - 1GB DDR 2700
O/S - Windows XP Pro 2008 Service Pack 3
Okay here we go...
Got a Sony 17" TFT screen plugged into the VGA out and my ACER LCD plugging in via DVI.
Here's the link to my graphics cards Tech Specs
GeForce FX 5200 - Tech Specs
Now why wont this new monitor go over 1280x960..push it any higher and the screen go black and displays out of range...Now i am using the drivers that windows automatically asigned upon installtion...I downloaded the latest set of drivers from the net and installed and when I do this the screens are all distorted and very large and the display preferences wont allow the colour to go about 4bit...thus I rolled back the driver and it works fine..
My motherboard annoyingly doesnt have a PCI-E slot and I can ill afford to start replacing motherboards..
AGP as you all know is dying and PCI-E is the way forward..I can get a new graphics card with upto 512Mb ram...though I have doubts wheather it would work and the specs dont seem to produce any higher resolutions that mine..just obv takes more power away from your CPU.
Any answers would be cool as....!!!
Cheers Guys+Gals...
ZenBassuk is offline   Reply With Quote
Old January 26th, 2009, 07:00 PM     #2 (permalink)
Anime Otaku
RobRich's Avatar
Welcome to TechIMO!
Sounds like a refresh rate issue. In the video card configuration for the affected display, try forcing the monitors native resolution and a refresh rate of 60Hz (pretty much universally supported these days).
Robert Richmond | TechIMO Community Relations Director
Infinite perceptions. One reality.
FanFiction.Net - Unleash your imagination.
RobRich is online now   Reply With Quote
Old January 26th, 2009, 07:11 PM     #3 (permalink)
In the display properties its set to 60hz as it auto selects...selecting the option to see all refresh rates only 60hz is shown..
Could it be the 2 screens have different refresh rates and it cant make up its mind what to do ?....
lol....
Old January 27th, 2009, 06:20 AM     #4 (permalink)
BipolarBill's Avatar
Since you have two LCD displays, you have to be certain that you are changing the refresh rate for the correct one. I would advise disconnecting the 17" long enough to get this sorted out.
MCSE, MCP, MVP and nut job
BipolarBill is offline   Reply With Quote
LG L226WTQ 22" Widescreen LCD Monitor issue gazjones105 Graphics Cards and Displays 3 December 27th, 2007 12:09 PM
HannsG - 27.5" Widescreen Flat-Panel TFT-LCD Monitor waynezo Graphics Cards and Displays 0 November 18th, 2007 01:22 PM
HannsG 19" Widescreen TFT Monitor mattyb240 Graphics Cards and Displays 3 July 21st, 2007 03:38 PM
New monitor, standard or widescreen bilbonvidia Graphic Design and Digital Photography 7 June 7th, 2006 01:35 PM
Widescreen Monitor sinhvien Graphics Cards and Displays 24 November 30th, 2004 12:54 AM
Is It Just Me? (3007)
Forty-six years ago today (6)
Internet Lost (5)
windows vista security holes (15)
Help getting around port 80 for camer.. (4)
Open With ..... Win7 (2)
Internet Lost (5)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
