Thread: Track stick buttons not working
February 19th, 2009, 09:05 PM #1Junior Member
- Feb 2009
- 5
The track stick moves the cursor, but the buttons to click to open files don't work. No response from the left one when clicked. The right on brings up a window that allows you to OPEN, but doesn't automatically open the file. The other button does nothing. Have been using a wireless mouse, giving the computer to grand-daughter without the wireless! Might have to give up the wireless also!! It worked fine at one point. Thanks! Nana
February 20th, 2009, 05:41 AM #2
Nana, you have to tell us what kind of computer you have. They are not all desktops or laptops or the same brand. Please be specific.
The first place to look is the Control Panel under Mouse. Check the assignment for your button there.
You do not need the mouse to make changes there. You can use the Tab key and arrow keys to navigate. You can use the Enter key to select.MCSE, MCP and nut job
February 20th, 2009, 10:32 AM #3Junior Member
- Feb 2009
- 5
Track stick buttons
BipolarBill, Thanks! I have a Compaq Armada M700 ~ a dino!! I went to the Control Panel and the mouse properties include buttons, pointers, pointer ops, wheel, and hardware. As I went through, they all apply to a reg mouse, not the track stick. Thanks for any help in advance. Nana
February 20th, 2009, 11:21 AM #4
Yeah - that thing is older than old.
Get updated pointer drivers here:
Compaq Armada m700 Notebook PC*-* Download drivers and software - HP Business Support Center
You need the "Easy Point" software.
If no joy, this unit is probably ready for the scrapheap. Frankly, I wouldn't give it to my enemy, much less a cherished relative.MCSE, MCP and nut job
February 20th, 2009, 11:42 AM #5Junior Member
- Feb 2009
- 5
It's old, so am I, thus it's hard for me to let go! The grand-daughter can junk it for me!! Thanks, I'll go to the site you suggested.
I just got a new~used Dell Latitude that is almost faster than I can handle!! Nana
February 20th, 2009, 01:10 PM #6Junior Member
- Feb 2009
- 5
BipolarBill, Went to the site you suggested.
Entered XP Pro as my OS. Went to Driver-Keyboard-Mouse&Input devices.
Easy access buttons------download or
PC Card ...---------download.
Don't see "Easy Point Software" download. I did lownload the Easy Access Buttons thinking that's what I needed. Ends up, that's not what I needed!! How do I get rid of the download, or do I need to worry about it? The computer doesn't have those buttons~remember it's a dino!! Looked and loooked for Easy Point, no success! Any other suggestions? Thanks, Nana
February 20th, 2009, 02:33 PM #7
Just toss the download. Installing it won't hurt anything anyway - it's made for that model.
No - this is a hardware issue. The button is probably worn out.
February 20th, 2009, 03:28 PM #8Junior Member
- Feb 2009
- 5
That's what I though when the download didn't help. Thanks for all the help ~ a wireless mouse works fine on the old dino! It's always nice to get confirmation from an expert!! Nana
Memory Stick not working
By agnewjamie in forum Storage RelatedReplies: 1Last Post: October 15th, 2007, 04:09 PM -
Buttons...
By EXreaction in forum Suggestion BoxReplies: 2Last Post: January 7th, 2006, 01:06 AM -
Mouse acting strange, buttons not working
By Wakeboarder141 in forum Technical SupportReplies: 5Last Post: January 29th, 2005, 09:03 AM -
One memory stick - fine, 2 memory stick - BSOD!
By themightyw in forum Technical SupportReplies: 20Last Post: January 26th, 2005, 01:03 AM -
Buttons for messaging not working
By The Real Bingo in forum Suggestion BoxReplies: 1Last Post: May 18th, 2004, 08:54 PM
Do I sense some resentment at a woman in a man's sport, nunya? Although I feel you're right about her chances.
