Hi all
i have a hp pavillion dv6000 since 2005 never had any troublw with it ,
but over the past couple months its gotten really loud when you turn it on...
i usually have it on for days on end on standby.....
because when i switch it on it takes ages to turn on....
but today it wont switch on at all....
there is a panel on the right of the the switch on button where there is options for mute / volume control / and an option to launch quickplay when i click the quickplay one it loads up automatically,
but the actually laptop wont,
ive tried removing all the battery
and then unplugging,
and trying to restart but nothing is working....
does this laptop have a reset button....i cant seem to find it??
i appreciate any help thank you.....
