Hi,
my Dell 1525 is about 18 months old, the battery won't charge anymore, so I bought a new one / from Goodbattery.com. It looks exactly like the original battery and fits perfectly / but the Dell 1525 says 'cannot communicate with battery'
The Dell 1525 charger seem to function, because the 1525 works fine as long as I don't disconnect it from the charger...
many thanks in advance for your help, Pinchat
