Drive not Ready. system Halted Error
Currently Active Users: 1573
Discussions: 200,988, Posts: 2,379,867, Members: 246,357
Old March 15th, 2009, 11:28 PM   Digg it!   #1 (permalink)
Hello All.
This is my 2nd problem post.
This is for my other PC
I just cleaned the tower casing for some "dust and debris" that always going inside the case and fan blowers. Anyways, after done house cleaning, the PC won't boot, and displaying the message, Drive not ready. system Halted.
I checked all the cables, and seems working fine. Checked the power supply. Im not sure if the power supply. So, I bought a new one. 500 Watts. The previous one is only 350W. Installed it, and still nothing wont boot. I decided to replace all the IDE cables. But still won't boot and displaying the same message. Checked the MoBo manual, I found that I have to replace the BIOS Battery if won't boot. Bought new battery. Reconfigured the bios to its default settings (boot via dvd), but Still the same message if i tried to boot via HDD.
I decided to use a boot CD (from Hiren), I was able to boot using the CD and navigate into my drive C, and Partitions. Used the HDD Regenerator, and was able to de-frag and remove drive errors. Still won't boot on its HDD.
So now, basically i already isolated some problems: not the power supply.. not the IDE cables.. not the front panel cables.. not the processor.. not the MoBo.. not the RAMs... i wonder if XP is the culprit..? I remember before we went home (from the office) there's this "windows update installing" at shut-down. I could not check the update as XP won't let me boot, and remove the damn KB. I was able to "manual" install a new XP, but i decided not to do it yet.
any tips..?
oopps.... my rig:
- Windows XP pro
- 512 SD-RAM (4x 128MB PC800)
- 500W PS
- Intel P4, 1.5 Mz
- Intel DG850 Mobo
- 64 MB Video Card (inno)
- Seagate 80 GB HDD
- 1x Sony CD-RW
- 1x LG DVD-Rom
- 1x 3.15 FDD
thanks
Burnok100
burnok100 is offline   Reply With Quote
Old March 16th, 2009, 10:51 PM     #2 (permalink)
the mobo detects the HDD from the bios setup. I'll try to remove the HDD from the PC and install that in another one. What i could not understand, is why the mobo boots up when i use a bootable CD and navigate into the HDD and its partitions? But when I select HDD boot, it wont boot at all... I'll try your suggestion, and post it back here.
Cheers !
Old March 17th, 2009, 02:31 PM     #3 (permalink)
Big_Daddy's Avatar
Maybe because it doesn't see the boot.ini file
Swan XT10 640K 20M HD Hercules Graphics
Big_Daddy is offline   Reply With Quote
Old March 18th, 2009, 12:05 AM     #4 (permalink)
guys,
i have located the boot.ini, but still won't boot... here's what i did yesterday.
- Got an old HDD, installed it as primary Master.. then removed all other HDD.
it boot up, but on its old os (win98 !!).. so i know the mobo is still alive.
- installed the other HDD, now as slave. I was able to navigate into its directories and partitions, that's good... but the prob now, my main files are located in MyDocs...
I will try to replace the boot.ini file and let us see...
thanks !
Bluetooth is not ready - error message ReayMackay Networking and Internet 0 February 9th, 2009 06:10 AM
Ready to take apart this hard drive with a hammer, please help Pinetree General Tech Discussion 8 March 2nd, 2007 03:08 AM
Boot Failure: System Halted HELPIneedSomeone Storage Related 11 April 16th, 2004 05:11 AM
Drive not ready-system halted 2000problems Applications and Operating Systems 1 May 16th, 2003 09:05 PM
Floppy drive inaccessible, not ready slabbo Storage Related 5 March 9th, 2003 03:33 PM
Is It Just Me? (3066)
Health Care Rationing (11)
Delete an OS (17)
Nvidia GTX 260 problem (10)
Internet Lost (5)
Jedi Academy Problem (3)
Desktop Calendar Application (1)
Looking for new motherboard (0)
Delete an OS (17)
cheap gaming laptop? (12)
Unallocated Space (2)
C# + LINQ Help (7)
Dynex DX E-402 (3)
cell phone won't work (0)
Can't open Word (12)
