Results 1 to 18 of 18
    Member Urge3's Avatar
    Apr 2002
    South Wales
    110
    Angry JPEG PROBLEMS HELP ME PLEASEEEEEEE
    Ok Please me. For some reason god knows how. I can no longer change bitmp into Jpeg it seems to have gone from my drop down menu. Also all my previous jpeg files I cant open I have re installed windows to no avail help me please.
    I know you guys wont let me down
    Neiko
    xxxxxxxxx
    Neiko
    Not Really a Member
    27,895
    what application are you referring to?
    "seems to have gone from my drop down menu"
    what are you using to convert them?
    Apr 2002
    South Wales
    110
    Im scanning things on then trying to add them to the internet you know when you go to save as then convert it to jpeg its not there anymore in paint all my applications
    Neiko
    Senior Member fatal xception's Avatar
    Dec 2001
    Wwwwaconia, MMMinnes
    845
    Try using Infranview.
    Apr 2002
    South Wales
    110
    any idea though as to why the jpeg would just go and how I can get it back
    Neiko
    Dec 2001
    845
    Have you tried the Export as...
    Some programs use this.
    Apr 2002
    South Wales
    110
    Im thick as poo please I dont understand
    I just downloaded that thing
    What do I do now
    Neiko
    Dec 2001
    845
    The program is at home and I'm at work. If no one has answered I will when I get home.
    Apr 2002
    South Wales
    110
    tHANKS i OWE U BIG TIME THANK YOU SO MUCH IT WORKSSSSSSSSSSSSSSSSSSSSS
    YOU ARE GREAT
    THANK YOU SO MUCH
    Neiko
    Dec 2001
    845
    Hey...no prob. Glad it worked.
    Ordained Mommy NeoStarO1's Avatar
    Arizona
    7,398
    I have that problem if i am useing MSPaint, however I just now use MS Photo Editor which allows me to save as Jpeg. Take your screen shot or pic and then paste as new image.
    NeoStar
    Edit: Oops took to long to post that one. and didn't relize the problem was resolved.
    Dec 2001
    845
    Hey Neostar.
    If I remember correctly, Infranview does a better job of converting and creates a smaller file. I am not at home so i can't verify the last part.
    shahani
    Guest
    I've been using ACDC (www.acdcsystems.com)-its shareware but if you don't register you can continue using it with a nag screen.
    It is absolutely the best image viewer/convertor/organizer I have ever seen or used. Can't edit images though.
    Senior Member dustyrun's Avatar
    Louisville,KY
    564
    Try using Micrografx Picture Publisher 10.
    beenusing it since 8 and Like it a lot better then Photoshop..
    Rick
  15. #15
    Dec 2001
    845
    Ok...here's what I did.
    I took a small GIF and saved it in a PSD format.
    I then opened Photoshop and saved it as a JPG - on the highest quality setting it was 8.69k
    I then resaved the PSD to JPG on the lowest quality setting - 4.34k
    I used Infranview to open the PSD file (it's really cool it will open these files) and saved it as a JPG - 1.83k.
    From what I could tell there was no differance in the quality.
    Keep in mind this wasn't a really high quality pic, I'll try that later.
    Not bad for a free program.
  16. #16
    May 2000
    330
    Thumbs up
    Picture It works good too.
  17. #17
    Cruizing
    Wellington, NZ
    4,396
    yep I like acdc too
  18. #18
    Apr 2002
    South Wales
    110
    Thank you all The problem is resolved however Im gonna try that other one as well.
    Thanks soo much
    Neiko
What is 10 and 5 added together?
