Output of CCTV system to VGA
Currently Active Users: 1228
Discussions: 204,487, Posts: 2,419,112, Members: 249,908
Old August 31st, 2009, 08:35 PM   Digg it!   #1 (permalink)
I'm trying to replace a color monitor that has a BNC cable input from a cctv system. We wa to use a PC monitor and some sort of a converter. Is the output from a CCTV camera/system the same as composite signal ?
STUM is offline   Reply With Quote
Old September 1st, 2009, 05:48 AM     #2 (permalink)
glendalf81's Avatar
no the signals are different one is analogue (bnc) and the other is digital (vga) you will need something like this (BNC) to VGA Converter by CCTV Gadgets
E6550/4gbDDR667/gts250/WD320/WD250/win7ultimate(x64)msi p43 neo-f
glendalf81 is offline   Reply With Quote
Old September 1st, 2009, 08:30 AM     #3 (permalink)
I know there is a difference between the BNC analog and VGA. What I need to know is .... Is a BNC analog signal the same as a composite video that would be on a RCA style jack ? I have a converter for composite video to VGA But the image doesn't stay in-sync. I'm trying to figure out if the converter I have is broken or am I have the wrong convert for the job ?
Old September 1st, 2009, 01:12 PM     #4 (permalink)
glendalf81's Avatar
sorry misread your post,
by all accounts yes they are check out this forum the OP has a similar request
Convert BNC Composite Video to VGA - Tech Support Guy Forums
Old September 2nd, 2009, 08:26 AM     #5 (permalink)
THANKS ! I hoped that the signals were the same.
Old February 17th, 2010, 02:30 PM     #6 (permalink)
same signal
Since we are talking about CCTV system (assuming a DVR unit), the analog output signal is the same as the composite one you are talking about (RCA jack). In fact you can switch between bnc to RCA with just a simple adapter:
But if you need to convert from an analog one to DSub (VGA) then you will need a special converter. Make sure you get a good quality one, I've tried a few of these and some of the cheap ones are just poorly designed/made. they will give you horrible display output and/or won't start back up after a power outage (but you want to use an UPS anyway). This is the one I am using now and recommend:
http://http://www.dvrsecuritylab.com/home-security-systems/bnc-to-vga-converter.html
Nonetheless, if you are going to upgrade the system, make sure you get one with a vga output built in. Those work the best.
Hope this helps.
Rogitson is offline   Reply With Quote
Help with CCTV setup... Nude_Lewd_Man General Tech Discussion 14 October 24th, 2008 09:28 AM
DOubling System and VGA RAM Overclocker01 Graphics Cards and Displays 1 March 7th, 2006 01:55 PM
System failed VGA test? LAPhotoPro.com Graphics Cards and Displays 0 March 28th, 2005 08:16 PM
New built system: no output to monitor The Mad Jock Technical Support 13 April 1st, 2004 06:05 PM
Is It Just Me? (1526)
CBO: Obama's health care plan cuts .. (57)
would this build be enough for WOW? (14)
The Local Weather Thread (701)
Recent Problem (9)
Suggestions? (6)
Want a new power supply for my Dell.. (35)
Motherboard the culprit? (5)
Can't Rename Files (11)
[ F@H Chat] 03/07/10 New Month New.. (88)
Need some suggestions on building a.. (21)
I need help Guess what happened to .. (5)
Windows XP Pro Error log (6)
My PC shutsdown after 30 minutes of.. (5)
How to Remove DRM from Protected Vide.. (0)
Audio skips when I play a cd or dvd o.. (0)
Computer For Sale*Media Center*Motoro.. (0)
Replacement hard drive for Dell 600M (17)
Recent Problem (9)
E:\Pictures is not accessible. the d.. (2)
Want a new power supply for my Dell. (35)
Selling Xbox Live 1 month codes!!! [$.. (1)
[ F@H Chat] 03/07/10 New Month New T.. (88)
Suggestions? (6)
Drive 0 not found: Serial ATA, Sata-0 (7)
3D Pinball for Windows High Score (122)
mac noob in need of help please (0)
Hard drive full = slower computer? Is.. (4)
Processor speeds? (19)
Clean up safe to delete? (4)
Where to buy 3Rsystem Iceage 120 Boss.. (3)
Need some suggestions on building a g.. (21)
2.6.12, Linux kernel (3)
I need help Guess what happened to my.. (5)
Can 2 cards run off 1 pcie 16 slot (2)
Microsoft removes hardware virtualiza.. (0)
