September 16th, 2009, 06:46 AM
| Junior Member
| Quote:
Originally Posted by glendalf81 the short answer is NO it has been specifically designed to output 12v 18a and as far as i know such an adapter to reduce the amperage does not exist, what do you want to use it on | and they call this a tech site... you can't force "over current" something(you can force high voltage though..) If the device has a current draw of 15 amps, it will only draw 15 amps from the supply, assuming that the power supply can support the draw. Think about it like this- You can run a single christmas light off of a car battery, and it will still only draw .00001 amps and manage not to burn out. Despite the fact that there might be 1000+ amps of juice capacity available for consumption in the battery.
And besides, it's a "switching" power supply, meaning it turns on/off its internal power transistors when power isn't needed. It is not "designed" to operate only at it's maximum current potential lol.. In fact it will last a lot longer when not always using max potential of the supply.
Find a pin diagram of the connector(its same or similar as pci-express power connector i think). Cut off the end. Splice the wires, run all the 12+v and 12v-(ground) in parallel(twist all 12v+ together, also twist all 12v- together). If there is a "remote" wire, run it in parallel with the 12v- and it should power on.
