Need Help With Computer Build
Currently Active Users: 2534
Discussions: 201,008, Posts: 2,380,092, Members: 246,374
Old September 18th, 2009, 09:10 PM   Digg it!   #1 (permalink)
I am looking into building my first ever computer and i just wanted to make sure everything that i am buying goes together and is of quality. I would hate to spend hundreds of dollars only to realize one part doesn't go with another part.
Any help would be greatly appreciated.
Hardware:
CPU- Intel Core 2 Quad Q8200- Newegg.ca - Intel Core 2 Quad Q8200 2.33GHz 4MB L2 Cache LGA 775 95W Quad-Core Processor - Processors - Desktops
Case- Raidmax Smilodon Extreme Black ATX with 500W psu- Newegg.ca - RAIDMAX SMILODON Extreme Black ATX-612WEBP 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case With 500W Power Supply - Computer Cases
Motherboard- GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel - Newegg.ca - GIGABYTE GA-EP45-UD3L LGA 775 Intel P45 ATX Intel Motherboard - Intel Motherboards
Memory- G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Newegg.ca - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL6D-4GBNQ - Desktop Memory
Hard drive- Western Digital Caviar Blue 320 GB 7200 RPM SATA- Newegg.ca - Western Digital Caviar Blue WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - Internal Hard Drives
Video Card- SAPPHIRE 100236-1GVGAL Radeon HD 3650 1GB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready Video Card- Newegg.ca - SAPPHIRE 100236-1GVGAL Radeon HD 3650 1GB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready Video Card - Desktop Graphics / Video Cards
And again any help at all would be greatly appreciated.
shadowpoet888 is offline   Reply With Quote
Old September 18th, 2009, 09:25 PM     #2 (permalink)
Aaron_8015's Avatar
Send a message via MSN to Aaron_8015 Send a message via Skype™ to Aaron_8015
Hi and welcome.
What are you planning to use this computer for?
What is your budget?
Either way I would recommend you pick a different case preferably one that does'nt have a PSU with it. Some say Raidmax is okay but I don't like them so I would suggest mabye a 400W OCZ PSU (even though 400W is overkill for that system).
If you are planning on using this for games I would suggest to pick up a WD caviar black and a better gpu (9600, 4670 etc).
Q6600//6gb//2x 260GTX//2x raptor + 750gb//Antec EA650//Lite-on DVDRW//Msi P7n D + X-Fi //Antec 900
''I dont suffer from insanity. I enjoy every minute of it.'
Aaron_8015 is online now   Reply With Quote
Old September 18th, 2009, 10:18 PM     #3 (permalink)
JLK03F150's Avatar
Send a message via ICQ to JLK03F150
Hi and Welcome to TechIMO
Let me be the first (ok, second ) to say Raidmax makes crappy power supplies. Here's an alternative though, an Antec Sonata. I'm still using my Sonata series I case (with an upgraded PSU) that I bought in 2003. It's not flashy, but very functional & cools well.
Newegg.ca - Antec Sonata III 500 Black 0.8mm cold rolled steel ATX Mid Tower Computer Case 500W Power Supply - Computer Cases
For 50 cents more 5-5-5 RAM is better (faster) than 6-6-6.
Newegg.ca - G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPK - Desktop Memory
Rest peacefully little furry beast
JLK03F150 is offline   Reply With Quote
Old September 18th, 2009, 10:40 PM     #4 (permalink)
First off I generally agree with what's been said above, I personally tend away from comboed case/psus, but if you like the case the psu should be fine.
Second, what's your budget, and what do you plan on using the computer for? I think the common assumption includes some gaming, which would lend to getting a better graphics card.
Lastly, one thing to think about is that the intel i5 chips just came out. The cpu and ram are going to be a bit more expensive (only takes ddr3), but you'll have a system that will last you a good while longer, and have far superior upgrade potential later on. I'd say the price premium for the i5 setup would probably be an extra $100.
Intel i7 920 @ 4.0 ghz, ASUS P6T
6gb Corsair XMS3 DDR3 1600, EVGA 275 GTX 896mb,
CM RC-690, WD Raptor 150gb, WD 2x1tb cav green.
thephilosophizer is offline   Reply With Quote
Old September 18th, 2009, 11:01 PM     #5 (permalink)
JLK03F150's Avatar
You're right philosophizer, i5 would provide a much better upgrade path. But, as you said, there would be added costs. I was only commenting on improving the build as listed.
Also as both of you guys stated, if the build is for gaming then a budget increase is needed for better video.
New Computer Build! Morbin581 General Tech Discussion 0 September 6th, 2009 06:59 AM
New Computer Build HELP! (Please look over new build)??? roosta21 General Tech Discussion 30 June 29th, 2008 10:08 PM
New computer build Arget General Tech Discussion 4 June 18th, 2007 12:48 AM
My new computer build matthewd General Tech Discussion 4 July 27th, 2004 03:21 AM
How to- Build a computer Rand Dusing General Tech Discussion 7 September 1st, 2003 10:00 PM
Is It Just Me? (3137)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (6)
Nvidia GTX 260 problem (14)
Delete an OS (18)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
