Hi, Im a first time poster here, having some graphic card problems..
My specs..
AMD Athlon 64 3000+ @ 2000 MHz
2048 MB (2 x 1024 DDR-SDRAM )
NVIDIA GeForce FX 5200
MSI K8T Neo-V (MS-7032)
PCI and AGP bus
Please dont laugh..lol..anyway..as you can see I have a crappy video card..so I just purchased an EVGA NVIDIA 8400 GS..AND a new psu, 550 watt, should be plenty to run the card.
So..I uninstall the old drivers..even use Driver Sweeper to make sure..install the new card..and drivers..everything is fine until reboot..then I get a totally pixelated screen. Its neon colors and cant read anything on it..btw.its a PCI card..so it says..and I have both PCI and AGP bus slots.
Screenshot:
Zi6_0290.jpg picture by Faerytear - Photobucket
Strange thing is..I go into PC Wizard to see..or BARELY see..what its saying about the card..it is saying its PCI E..at least I THINK it says that..
I tried getting into my bios..and no luck..I have a razor keyboard and no matter what key I hit..I cant access bios..
What do you think is wrong..is it the graphics card itself? Just got it from Tiger Direct..hmmm
I really cant afford to spend any more money! Im a single mom and it was bad enough buying a psu and card. HELP!
