PLEASE HELP STRANGE PXE ERROR!!!
Currently Active Users: 2608
Discussions: 201,007, Posts: 2,380,085, Members: 246,373
Old October 29th, 2009, 07:07 PM     #11 (permalink)
its seagate
always7777 is offline   Reply With Quote
Old October 29th, 2009, 07:11 PM     #12 (permalink)
Millwright
stroyal's Avatar
Originally Posted by always7777 View Post
but i cant use floppys or cds all it has is 3 USB ports. can i connect a CD drive through tthe USB port even though the computer wont start up?
If you got into the BIOS, the computer starts.
If the BIOS lets you BOOT from USB it will BOOT, unless there is something else wrong.
A hard drive is not necessary to BOOT a PC, in the old days we didn't even have hard drives, we ran completely on floppies.
Hard Sayin Not Knowin
stroyal is online now   Reply With Quote
Old October 29th, 2009, 07:14 PM     #13 (permalink)
Millwright
stroyal's Avatar
Here ya go.
Internal Downloads | Seagate
Try Seagate tools.
Edit: Hard drive not working after a drop is almost always, a dead hard drive.
It's mechanically broken probably.
There are laptops that lock the hard drive when it senses a drop, to save the drive, but I don't know anything about them.
I'm skeptical as to whether they realty work though, and I doubt you have one.
Old October 29th, 2009, 08:50 PM     #14 (permalink)
to F@H or not to F@H ?
Cmptr-Gy-Dv's Avatar
a few days ago i dropped my acer netbook ;[ it shut off and when it restarted i got this boot screen messag error w.e:
In tel UNDI. PXE-2.1 (build 002)
Copyright (c) 1997-2000 intel corperation
for atheros PCIE Ethernet Controller
Check cable connection...!
PXE-MOF : exiting intel PXE ROM
no bootable device -- insert boot disk
then it just kepp going over and over can someone explain to me what this means and how it might be remidied =[ i havent tried anything yet ive just stared and gotten pissy
it's trying to boot to a network using PXE, the boot order is changed, go in to the bios and set it to boot from hard drive first, and turn off the PXE boot,
i'm folding for techimo!! what are you doing?
Cmptr-Gy-Dv is online now   Reply With Quote
Old October 29th, 2009, 09:10 PM     #15 (permalink)
Millwright
stroyal's Avatar
I saw that, but since the change took place after a drop, I suspected the HD.
always7777, did you make any changes in the BIOS to the boot order, or did it ever boot from a network?
Edit: I would think, if it did not find a network it would go to the HD, just like it skips over the Floppy or CD drive with no disk, if it is first in the boot order.
It's worth checking though.
Old October 29th, 2009, 10:59 PM     #16 (permalink)
your right I just set my box to boot with PXE and it just went back to hard drive,
so that must be just because he has it set to boot from other devices,
but this is a desk top, seems to me I had a laptop doing the same thing but it would not revert back to hard drive it would just show the PXE boot failed, but I could be wrong laptops are all different and mine was a dinosaur
Old October 29th, 2009, 11:18 PM     #17 (permalink)
Millwright
stroyal's Avatar
Yep, even desktops are all different.
I know when I think I have a symptom nailed as to the cause, the next time I see it, it is a completely different cause.
Old October 31st, 2009, 06:26 PM     #18 (permalink)
how do i take off the PXE boot or w.e i dont know how to remove things from the boot order list thing
Old October 31st, 2009, 06:59 PM     #19 (permalink)
you should just be able to disable the boot other devices option, or disable PXE boot
Old November 3rd, 2009, 06:24 PM     #20 (permalink)
well i give up lol now a more pressing issue does anyone know how to format the netbooks harddrive? lol
Strange error message Robert526 Technical Support 10 January 28th, 2006 05:27 PM
3com PXE error codes Thackersc General Tech Discussion 3 January 30th, 2005 01:47 AM
strange windows error Brainchild Applications and Operating Systems 4 June 7th, 2003 03:50 AM
Strange game error TOAD6147 Technical Support 8 June 13th, 2002 09:53 AM
strange error Chooco Webmastering and Programming 0 March 8th, 2002 06:01 PM
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Need idiot-proof help for building a .. (2)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
