PLEASE HELP STRANGE PXE ERROR!!!
Currently Active Users: 2411
Discussions: 201,011, Posts: 2,380,105, Members: 246,377
Old October 29th, 2009, 06:28 PM   Digg it!   #1 (permalink)
a few days ago i dropped my acer netbook ;[ it shut off and when it restarted i got this boot screen messag error w.e:
In tel UNDI. PXE-2.1 (build 002)
Copyright (c) 1997-2000 intel corperation
for atheros PCIE Ethernet Controller
Check cable connection...!
PXE-MOF : exiting intel PXE ROM
no bootable device -- insert boot disk
then it just kepp going over and over can someone explain to me what this means and how it might be remidied =[ i havent tried anything yet ive just stared and gotten pissy
always7777 is offline   Reply With Quote
Old October 29th, 2009, 06:37 PM     #2 (permalink)
Millwright
stroyal's Avatar
I'd say for some reason, probably the drop, your your hard drive with the operating system is not working.
Check for loose connections, then download the hard drive manufacturers test disk.
As a quick check on the rest of the computer, try any BOOT floppy or CD and see if it will BOOT.
Welcome to TechIMO!
Hard Sayin Not Knowin
stroyal is offline   Reply With Quote
Old October 29th, 2009, 06:39 PM     #3 (permalink)
well o.o it doesnt have a floppy or disk drive and i wouldnt know how to check for loose connections XD im such a newb ;[
Old October 29th, 2009, 06:50 PM     #4 (permalink)
Millwright
stroyal's Avatar
Checking the inside of a laptop is no picnic, even if you are not new.
It's pretty hard to test without another boot able device. Can you get into the BIOS?
Can you borrow a USB floppy or CD, and will your BIOS let you BOOT from a USB device.
I'm pretty sure your hard drive is dead from the drop.
Old October 29th, 2009, 06:54 PM     #5 (permalink)
yes i can get into the BIOS and it does let me boot from a USB but i dont know how to install or put a program on a USB that would be bootable
Old October 29th, 2009, 06:59 PM     #6 (permalink)
this is what i get from my netbook after it shows the acer start page
Old October 29th, 2009, 07:03 PM     #7 (permalink)
Millwright
stroyal's Avatar
If it is a USB floppy or CD you don't have to make your own disk.
Any boot disk will work ie. win 98 boot disk, Your XP installation CD.
The test disk that can be down loaded from your hard drive manufacturer is also a boot disc, floppy or CD.
Old October 29th, 2009, 07:04 PM     #8 (permalink)
Millwright
stroyal's Avatar
The, "No Bootable Device" says it all.
Does the BIOS tell you what brand hard drive you have?
Old October 29th, 2009, 07:05 PM     #9 (permalink)
but i cant use floppys or cds all it has is 3 USB ports. can i connect a CD drive through tthe USB port even though the computer wont start up?
Old October 29th, 2009, 07:07 PM     #10 (permalink)
so this means my harddrive is screwed right? lol
Strange error message Robert526 Technical Support 10 January 28th, 2006 05:27 PM
3com PXE error codes Thackersc General Tech Discussion 3 January 30th, 2005 01:47 AM
strange windows error Brainchild Applications and Operating Systems 4 June 7th, 2003 03:50 AM
Strange game error TOAD6147 Technical Support 8 June 13th, 2002 09:53 AM
strange error Chooco Webmastering and Programming 0 March 8th, 2002 06:01 PM
Is It Just Me? (3139)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (6)
Nvidia GTX 260 problem (14)
Delete an OS (18)
A good PSU? (11)
Best file format to play on Windows H.. (1)
Please Help. (2)
winrar decompresses, but video gone (0)
Advice for stopping IRQ BSOD is win7 (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
