Results 1 to 4 of 4
    Dec 2009
    2
    Problem with output to Monitor
    Ok, so, I'm having some problems with my PC. Its a few years old but I've been away for the last year and a half, its been in storage and hasn't been touched since I left. I booted it yesterday and it worked fine for about 15 minutes, then the screen went blank. The monitor was still on (green light) but there was nothing on the screen.
    Now if I plug out the monitor cable from the back of the machine, the monitor will go to standby (orange light) and then if I plug the cable back in I get visual for about 20 seconds then the screen will go blank again.
    Now I thought it may have been the DVI adaptor I have been using (its a vga plug on the monitor) but I've tried another and its the same situation. I have also tried the monitor on another machine in the house and it works perfectly.
    I have Dual NVIDIA GeForce™ 7800 GTX PCI-E 256MB's running in the machine, I've tried both individually and in different configuarations but its the same issues everytime.
    The only thing a friend of mine suggested (he had the same problem it seems) was replacing the bios battery, but from everything I've googled about the bios battery does not apply to the problem I seem to be having.
    I'm at my wits end here, it was working perfectly before I left, would anyone have any clue of what possibly might be my problem?
    My Mobo is an Asus nForce™4 SLI™ Chipset Motherboard PCI Express and running Windows XP
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,059
    Sorry , but it is not that uncommon for a computer that has not been used for a long time to have problems. It just happened to me, a few months ago.
    The first thing to try is re-seat everything, then it is just a case of regular trouble shooting, by trying your parts in a working computer, or trying know working parts in your computer.
    Fortunately the last time it happened to me it was a corroded power switch.I think corrosion it the biggest problem with sitting around.
    Use a volt meter to check the battery.
    Memtest86 - Download Page
    Download the hard drive manufacturers dick to test you hard drive.
    Remove all cards and devices, not needed to boot, if it boots add them back one at a time.
    Minamum boot :Mother board, CPU, Video, 1 stick of memory, and Power supply.
    Welcome to TechIMO!
    Hard Sayin Not Knowin
    Dec 2009
    2
    Hi Stroyal, thanks for the quick reply, I manage to find the problem, turns out it was my monitor all along. When I tested it on my old machine yesterday I didnt leave it on long enough for the problem to develop, but I've tried it for longer just now and the same situation was happening on the other machine (Which is now my familys machine so is used quite regulary) And as it happens tried the old monitor on my machine and its working perfectly.
    Thanks for all the advice
    Dec 2002
    New Hampshire
    8,059
    Glad you fixed it, good thing I didn't say " It is almost never the monitor".
  1. Using External Monitor Output on Dell M1730
    By amk136 in forum Graphics Cards and Displays
    Last Post: December 22nd, 2008, 11:45 PM
  2. Output Monitor image onto TV
    By nemowolf in forum Graphics Cards and Displays
    Last Post: May 1st, 2008, 09:35 AM
  3. No Output to Monitor
    By DouglasFir7 in forum Technical Support
    Last Post: December 10th, 2007, 03:42 PM
  4. No beeps or monitor output. Light on, fan spinning.
    By CyberGenesis in forum Technical Support
    Last Post: February 20th, 2007, 06:33 PM
  5. New built system: no output to monitor
    By The Mad Jock in forum Technical Support
    Last Post: April 1st, 2004, 07:05 PM
