AIM/AOL PROBLEM!!  | | |
June 24th, 2002, 04:24 AM
| hey this is me again wit another PROBLEM, im full of em!! okay im at my friend Ashleys house and her AIM wont Direct Connect, maybe you ppls know what im talkin about so if u do please try to help! its a Toshiba Pentium1 Notebook, kinda old. er internet connection is thru AOL so maybe that clues u in on how i might have a problem. but who knows...
Thankx in advance like always
*Danielle*
*~*fender*~*
June 24th, 2002, 04:39 AM
| | dword to your moms
Is she behind any sort of firewall? |
June 24th, 2002, 04:42 AM
she doesnt even have a firewall! lol |
June 24th, 2002, 04:43 AM
there is a setting in aim in prefences> Im Image at the bottom you might try checking the box with something like use different address if using Aol. |
June 24th, 2002, 04:49 AM
didnt work!! hmmm any other wayz i could fix it???!!
THAnKX IN ADVANCE PPLS
*danielle* |
June 24th, 2002, 05:04 AM
| | dword to your moms
| http://www.aimhelp.com/aimtips/fixtimeouterror.php
Well, that is all I have found thus far, what as mentioned above. Have you checked to make sure the computer you are trying to connect to is accepting the connection? I know it sounds simple, but gotta knock out the obvious first. I'll keep looking. Oh, and I don't know if it would make a difference, but are both the newest version of AIM? |
June 24th, 2002, 05:36 AM
This is kinda off topic but I see "I Dunno NEthing"'s message text in a different font than the standard one. Anyone else see this? Her reply a couple posts down shows up in the normal font.
Ruahrc |
June 24th, 2002, 05:46 AM
| | dword to your moms
Ruahrc all looks normal to me. |
June 24th, 2002, 05:51 AM
| | just passin thru
I've had several contacts who cannot direct connect because either they are using an older version of windows, aol or there on a mac. I'd say that's probably the reason. Find out what operating system she is running and when you try to direct connect , find out the OS on the other side. I run XP and I cannot connect to several people running older version of AOL, and Win. 95.
P4 3.2 'E', 4GB DDR400, XFX Geforce 6600GT 256MB AGP, MSI 865PE Neo2-P, WD S-ATA II 500GB HDD, Win. Vista
June 24th, 2002, 07:29 AM
| | A hero in training
also there isp side might be running some sort of firewall or filter. there are serveral people i can connect to, and others i can't for some odd reason |
