External hard drive problem, please help!
Currently Active Users: 1677
Discussions: 221,040, Posts: 2,604,079, Members: 272,932
Old February 2nd, 2012, 04:36 AM     #1 (permalink)
Hello,
I have an Apacer AC202 500GB external HD. As in one point of time my drive stop working properly I decided to reformatted. I wanted to do it through the device manager and not the quick format but not along after the formatting process start its seems that the HD follow asleep and a message formatting cannot be complete pop up. If I do a quick format there isn`t any problem and the HD is ready for a use in a seconds but I`m sure that I`ve got some bad sectors and I`m afraid that the quick format will not fix them. I hope that someone could give me an advise of what to do. By the way my laptop is using windows 7 as OS.
Thanks Pam
plam is offline   Reply With Quote
Old February 2nd, 2012, 06:32 AM     #2 (permalink)
Millwright
stroyal's Avatar
Welcome to TechIMO!
I assume 2 posts was a mistake.
Quick format, just re-wrights the index, so no it would not find bad sectors.
Seems to me the last time I played with a hard drive with bad sectors, I had to go back to a win98 format, to mark bad sectors, as I don't think XP or newer dose that.
I think it just tries to repair.
The hard drive manufacturer, has a downloadable disk, that will test the drive. Unless it is one of the crappy brands.
This is a very accurate test, and can be trusted.
I don't thing anybody tries to recover a failing disk anymore, but another option that works, is watch at what percentage the format stops.
Say it is 75%.
Then partition the drive to 70%, and leave the rest unpartitioned. I had a drive last for years after doing that.
Of course, if format fails @10%you would loose 90% of the drive.
Really nothing I would do today.
Hard Sayin Not Knowin
stroyal is offline   Reply With Quote
Old February 3rd, 2012, 03:36 AM     #3 (permalink)
Hi ,
Thanks for your replay. Yes I wasn`t sure where exactly shall I put my post and by mistake I`ve done 2 post.
I did a quick formatting to the drive and after I scans the hard disk for errors and attempts to fix them and surprisingly the scan worked this time. Shall I assume that the drive is fixed now?!
Old February 3rd, 2012, 07:05 PM     #4 (permalink)
Millwright
stroyal's Avatar
I don't trust any scan, except the one provided by the hard drive manufacturer.
Old February 7th, 2012, 03:06 AM     #5 (permalink)
I didn`t found any manufacturer scans . I believe that I`ll just go and buy a better HD and do the right formatting from the start.
Ask a Tech Question (free)!
This is evidence (153)
Is It Just Me? (3849)
NAS box or not? (26)
New PC gamer, can i run diablo 3??? (25)
Obama Touts Reforms After J.P. Morg.. (17)
Running Virtualbox with an AMD Proc.. (12)
Help Remove Babylon Search - Malwar.. (15)
need help with my rig (10)
Mic Playback (7)
Computer disconnects from network a.. (6)
Huawei Honor U8860 4" Android 4... (0)
bfg nvidia 7800 gtx (1)
Word, NOT saving (2)
Socket FM1 CPU "Requires discret.. (9)
XP has gone cyclic missing SXS file o.. (9)
Display Problem (5)
need help with graphics card (2)
Need help with cpu installation (8)
Help Remove Babylon Search - Malware? (15)
Running Virtualbox with an AMD Proces.. (12)
All browsers randomly crashing and BS.. (4)
Accessing computers in LAN(connected .. (2)
New GTS 450 freezing PC (32)
my graphics card doesn't work (1)
Need new PC advice (recommendations) (0)
what card should i get (1)
VMware and BF3 (0)
GRAPHIC CARDS (1)
Control 2 computers with 1 mouse and .. (6)
Radeon HD 4870 can't update, please h.. (3)
which graphic card to buy (1)
Upgrade my memory? (3)
Need help (0)
external hard drive problem sue.elm Technical Support 8 May 3rd, 2012 10:25 AM
External Hard Drive Problem on Win7 pjlsh Technical Support 3 March 12th, 2011 09:11 PM
external hard drive problem adc4x Technical Support 3 January 17th, 2009 11:46 PM
external hard drive problem david747 Technical Support 1 May 18th, 2005 04:48 PM
TechIMO Copyright 2012 All Enthusiast, Inc.
