 | bought a wrong graphic card help! |
February 8th, 2012, 11:50 AM
need help i bought the wrong grahic card and now i need to buy one that works here the one i currently have
nvidia geforce 4 mx 440 with agp8x
February 8th, 2012, 12:45 PM
| | Goverment property now
Please dont make multiple post, one is only needed.
February 8th, 2012, 12:52 PM
February 8th, 2012, 01:57 PM
| | PC Upgrade Procrastinator
so is that one the one you had, or the wrong one you bought?
With out any more info on your PC's specs, size of your case, power supply specs, etc, no one can really suggest anything to replace the old one yet.
__________________ i7 920@2.66/Corsair H60//MSI X58 Platinum//6GB DDR3 1333//GTX 470//GTX285 For PhysX//HTO Striker 7.1//Corsair 750TX//CM 690 II Advanced//Win7 64//250GB, 2x250GB RAID 0, 500GB, 500GB TechIMO Folding@home Team #111 - Crunching for the cure! |
February 8th, 2012, 02:21 PM
February 8th, 2012, 02:30 PM
February 8th, 2012, 02:32 PM
alright thanks for the fast reply ill try to find one at amazon
February 8th, 2012, 02:37 PM
Even a Radeon 3650 or 3850 In AGP 8x Flavor would be a suitable Upgrade. if you can find one of those.
If you stumble upon a Radeon 4670 in AGP, THAT is the card I'd get, its similar to the 3850 in performance, and runs at lower power from what I remember, plus should be a shorter length card.
and the 4670 was the LAST AGP card made for AGP Slots, after that, no more AGP gaming cards were made. Nvidia Stopped AGP cards with the Geforce 8 series that predated the 4670 by 2 generations already.
