Page 1 of 2 1 2 LastLast
Results 1 to 20 of 23
    Senior Member Good Companion's Avatar
    Scottsdale, Arizona
    525
    Power supply or switch?
    Having a weird problem on my self built desktop. Machine has been running well for years with various incarnations of upgrades. Power supply is a few years old.
    When I push the "on" button, I get a green LED that lights up but nothing happens. I think I hear a faint clicking, but I don't think that's hard drive clicking. I say faint because I can hear it only (I think) because none of the fans are running.
    When this first happened I checked the power cord in the back, cycled the power switch in the back and cycled the power switch on my surge protector. Pushed the button again and it worked. However, it happened again last night. Did the same and it worked again.
    I'm thinking either Power Supply is flaking, switch on the front of the case is going bad or maybe the surge protector is flaking. Any thoughts? Any ideas on how I could test these theories?
    " ... and you'll need a good companion for the ride ..."
    Bruce Springsteen, Land of Hope and Dreams
    Jan 2003
    Outside the box
    8,489
    4
    Well it might sound a bit obvious here but you could eliminate two of your theories right off. One remove the surge protector from the equation and plug the machine straight into an outlet. Two eliminate the switch, just open the side of the case, locate the header with the power jumpers. You don't need the switch there to turn the machine on all you have to do is briefly short them.
    The power supply is a bit trickier. You'd need a voltmeter or something to test the output.
    Scottsdale, Arizona
    525
    While a bit obvious, still appreciated. I'll bypass the surge protector tonight and see what happens. On the switch, do I just use an extra part from an old MB install to short it? (Like the small rectangle used to short a hard drive from master to slave?)
    Jan 2003
    Outside the box
    8,489
    4
    No once you remove the wires to the power switch all you need is a screwdriver or something metal and it only needs a quick touch to make contact. If the switch was indeed bad the board should fire up. If not then you are back to square one.
    Scottsdale, Arizona
    525
    I tried plugging the PC directly into the wall. Same thing, did not turn on but heard a faint clicking. Opened the side and removed the wires to the front switch. Used a screwdriver to jump the connector and same thing. Since I could look in, what I saw was the my fan at the back of the case (not the PS fan) spinning lazily (not at full speed) and 4 lights on MB flashing that say "PhaseLED" near them. It's a Gigabyte GA-H55M-S2H board. The PS is an Antec Smartpower SP-500 (500w).
    So, since the fan on the PS does not come on immediately, I'm thinking the PS is dying. Thoughts?
    Scottsdale, Arizona
    525
    Jan 2003
    Outside the box
    8,489
    4
    Well if you have a multi-meter handy you could pull the power supply, jump start it with the paperclip trick and test it out. Even if you don't I might try that before buying anything.
    You might also want to pull everything out and check the board and parts for any bad caps or any signs that something might have burnt or be failing.
    Scottsdale, Arizona
    525
    I have a multi-meter and I googled the paperclip trick. What exactly am I measuring with multi-meter? (Meaning, where am I putting the leads and what am I looking for?)
    I took a look at the board and it still looks close to brand new. No obvious black or brown anything in there.
    BTW, thanks for the help!
    Jan 2003
    Outside the box
    8,489
    4
    Check the voltage according to the pinouts this should give you an idea Driverheaven Guides: testing your psu with a multimeter
    here are the pinouts, or what should be close
    File:ATX PS signals.jpg - Wikipedia, the free encyclopedia
    JP might be able to walk you through it a little better than I can
    Scottsdale, Arizona
    525
    Well, here's what I get with a multimeter (set to 20):
    3v - .3 to .01
    5v - 1.8 to .2
    12v - 5.7 to 1.8
    I'm assuming that this is volts (as opposed hundreths of volts or tenths of volts) and that this PS is not generating enough to run a fan, much less the whole computer.
    Minnesota
    17,431
    Can you post your full hardware specs, just in case you need to get a new PSU to replace it, give a better idea of what you would need for a replacement.
    But will wait for JP to stop in and see what he has to say. can't comment on the Multimeter readings myself, have never done that, so no idea what the settings are for testing and what the readouts mean.
    Scottsdale, Arizona
    525
    Full specs:
    Intel i3-540 (3.06 Ghz)
    Corsair 4GB DDR3 PC1333
    Antec Smartpower 2.0 500w PSU
    LG GSA-H10N 16x DVD-RW DL
    Hitachi 750 GC SATA HD
    WD 160 GB IDE HD
    Millwright stroyal's Avatar
    Dec 2002
    New Hampshire
    8,063
    If you have the multi-meter set to DC, I'd say you have a bad power supply.
    And of course, the multi-meter is accurate.
    Hard Sayin Not Knowin
    Scottsdale, Arizona
    525
    Multimeter def set to DC. (Followed the guide linked earlier in this thread.) Accurate? No idea why it wouldn't be ...
  15. #15
    Jan 2003
    Outside the box
    8,489
    4
    It has been awhile since I've tested a psu with a multimeter so I thought maybe it was just me in thinking those numbers look totally off. Glad to hear I'm not alone on that one.
  16. #16
    Minnesota
    17,431
    Quote Originally Posted by Good Companion View Post
    Full specs:
    WD 160 GB IDE HD
    No video card? Just using the onboard/CPU graphics?
    Do you plan on adding a dedicated GPU later at any point?
  17. #17
    Scottsdale, Arizona
    525
    Oops, ATI Radeon HD 4850 (512 MB)
  18. #18
    Jan 2003
    Milwaukee, WI
    7,657
    Well if your doing it right, and it sounds as if you are, its pretty likely the power supply...
    Its rare that it acts this way when failing, but PSU's are notorious for the random issues they develop when unstable.
    I ssume your using integrated graphics?
    edit.. took too long to post...
    In that case you need a minimum of this PSU...
    Newegg.com - COOLER MASTER Elite 460 RS-460-PSAR-J3 460W ATX12V V2.31 Power Supply
    Thats the cheapest option you can safely replace the current PSU with...
  19. #19
    Scottsdale, Arizona
    525
    JP, I ordered this:
    Newegg.com - COOLER MASTER eXtreme Power Plus RS500-PCARD3-US 500W ATX12V v2.3 Power Supply
    Is that okay? It's a higher wattage, but I know that isn't the be-all end-all.
  20. #20
    Jan 2003
    Milwaukee, WI
    7,657
    Thats cool, Its actually cheaper, and essentially the same power supply with an extra years worth of warranty..
    It must have come down recently, or I'm not paying as much attention...
  1. Cooler Master Real Power Pro 1250w Power Supply Review
    By RobRich in forum Tech News Discussion
    Last Post: August 11th, 2008, 12:53 PM
  2. PC Power & Cooling Silencer 750 Quad Power Supply Review
    Last Post: May 15th, 2008, 06:32 PM
  3. Cooler Master Real Power Pro 850w Power Supply Review
    Last Post: April 18th, 2008, 09:32 PM
  4. I want to switch my power supply
    By crazynoob in forum Motherboards
    Last Post: April 12th, 2008, 06:15 PM
  5. Replies: 2
    Last Post: November 16th, 2004, 08:37 PM
