XP Desktop Problem
Currently Active Users: 1535
Discussions: 200,933, Posts: 2,379,173, Members: 246,297
Old July 9th, 2002, 02:45 AM   Digg it!   #1 (permalink)
Canuck
FreakyOCR's Avatar
Send a message via ICQ to FreakyOCR Send a message via MSN to FreakyOCR
XP Desktop Problem
"A friend of mine has just bought a dell computer and has windows XP installed on it...but everytime he turns off his computer or it shuts down, the desktop is erased and so are the files..and there is a message when the computer is turning back on, saying "cannot find a particular file"...do u know what might be the problem here?..im not too sure!
thanks for your time!"
This is what my friend wrote to me... unfortunatley I have never used win XP.... I assume it's a corrupted sector? Good 'ol Dell eh?
- Freaky
FreakyOCR is offline   Reply With Quote
Old July 10th, 2002, 02:28 AM     #2 (permalink)
Canuck
FreakyOCR's Avatar
Anyone?
Old July 10th, 2002, 02:49 AM     #3 (permalink)
Retired mostly.
Does this happen to all users or just your friend?
Heh, perhaps dell integrated a system restore utility that works everytime you bootup
I'm just guessing here.
-M
Old July 10th, 2002, 02:47 PM     #4 (permalink)
Canuck
FreakyOCR's Avatar
heh thanks muno...
Old July 10th, 2002, 06:24 PM     #5 (permalink)
piyopiyo13's Avatar
Send a message via ICQ to piyopiyo13 Send a message via AIM to piyopiyo13
What, specifically, are the files that the OS is saying that it cannot find?
piyopiyo13 is offline   Reply With Quote
Old July 10th, 2002, 06:34 PM     #6 (permalink)
I do Ouchy-Bleedy.
no1_vern's Avatar
Hi Freaky,
Did your friend say why he couldnt contact Dell??
I would suggest since the Comp is new that he contact Dell and talk to them, explaining what is happening. My last comp was a Dell and when I had problems the were pretty fast helping me get everything sorted out. That might have changed tho' I've heard Dells support isnt as good as it used to be.
If he cant get help from Dell, Can you find out the exact message he receives?
no1_vern is offline   Reply With Quote
Is It Just Me? (2877)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (0)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
