March 14th, 2012, 08:12 PM #1Junior Member
- Mar 2012
- 1
Upgraded CPU heat sink/fan. Pc will not turn on now.
Hey everyone this is my first post and I'm pretty desperate for some help.
Here's some info on my pc to start:
Mobo: Asus p7p55d-e pro
CPU: intel i5 1156
Psu: corsair tx650w
Gpu: nvidia gtx460
Ram: 2x 4gb corsair ddr3
Hdd: western digital. 1tb.
Case: cooler master 922 HAF
New heatsink: cooler master hyper 212 plus
Ok now for the problem. Today my new heatsink arrived and I proceeded to instal.
I removed all plugs from the mobo and removed the mobo itself.
I installed the heatsink exactly as shown in 2 different videos I watched. I hooked everything back up exactly as it had been before starting this.
The power led on the mobo lights up when plugged in. The wireless adapter that is hooked up via USB lights up. When I press the power button on my case, absolutely nothing happens. I have triple checked every cord inside my case. The only ones I'm unsure of are the 2 from my hdd since there are about 10 different places to plug them in, but I am about %90 sure I plugged them in where they were before I started.
I have a feeling I'm just overlooking something stupid, and I apologize if that ends up being the case, but I'm freaking out right now and I'd greatly appreciate any help on this.
March 14th, 2012, 09:34 PM #2
I'd start by double checking to make sure you got the wires for the power switch back in the right place. I've made that mistake a few times. From there its all about dis-connecting and reconnecting everything you removed just to make sure its in there firmly. You may also need to remove the motherboard again and put it back in, making sure you've got all the stand-offs in place, nothing is behind the board and its not grounding somewhere.
March 15th, 2012, 10:54 AM #3
You could have a short where the MB touches the case. Make sure you didn't reverse the Power SW. I usually remove all of those (Reset, HDD Light) and just do the Power Switch. If that works, plug in the next one.
Swan XT10 640K 20M HD Hercules Graphics
March 15th, 2012, 01:59 PM #4
I too would start with checking the connector that runs from your power switch on the case to the header on the motherboard. I've plugged it in backwards several times.
Welcome to TechIMO!
Good job, friend-of-friends!
Heat Sink fan is dying
By buttonpusher69 in forum Processors, Memory, and OverclockingReplies: 10Last Post: February 11th, 2007, 09:16 PM -
Need a quiet - good performing Heat Sink Fan
By ToneDeaf in forum General Tech DiscussionReplies: 5Last Post: March 8th, 2004, 04:36 PM -
Heat Sink and Fan w/ XP 2500+
By magwel in forum Technical SupportReplies: 9Last Post: September 24th, 2003, 10:55 PM -
Need Suggestions for Fan&Heat Sink
By mrjetguy in forum Processors, Memory, and OverclockingReplies: 9Last Post: September 3rd, 2003, 12:05 PM -
What is the Best Heat Sink/Fan For the price?
By Urban_Squrill in forum Processors, Memory, and OverclockingReplies: 11Last Post: June 30th, 2003, 10:36 PM
Tom's Hardware: Graphics Card Hierarchy Chart - April 2013
Radeon 7870 or GTX 660 - which is...
