March 28th, 2012, 10:48 AM #1
Churning Sound on Hard Drive. What Does It Portend?
Laptop started with a churning sound.
Then the screen was grey and an Error MessageLaptop was almost never used.OS Correction. May Take Several Minutes. May Start and restart"
Few minutes later--without restart--went to USER screen and asked for Password.
[I could not supply acceptable password...DK...several years since last use. Seperate issue.]
Is the Hard Drive on Laptop dieing a slow (or quick) death??
Any other possibilities, including bad sectors?
Is replacement almost immediately inevitable?
MegalosSkylakiFIRST EIGHT YEARS ANNIVERSARY HONOR ROLLthis April 18th, 2012 and will be Officially Celebrated That Day! SEE http://www.techimo.com/forum/imo-com...ml#post1070600
March 28th, 2012, 01:28 PM #2
Who makes the hard drive? If you go to the manufactures website, they have some scan tools that will give you a better idea on what the health of the drive is
March 28th, 2012, 03:01 PM #3
Or you can download HDtune and read the SMART data from the drive.
August 10th, 2012, 08:14 AM #4
My problem is a bit worse. The laptop keeps rejecting my password. I've even found a written version of password and still "No Joy". Maybe the failed state of the HDD has something to do with it, although I suppose I could try to crack the password just in case I have it wrong. (This was a laptop I left behind in CA as a backup for two years + and went unused.)
I'm thinking of using an "SSD replacement kit" to replace the probably bad mechanical HDD. As you may know, these typically come with an imaging software like Acronis Home or Norton Ghost plus an external device to hold the drive while imaging and transfer takes place. This optimistacally assumes the HDD still will work so I can pull the OS, drivers and proggies off it.
Question: Will a failed Password be a problem in imaging and transfer?
MegalosSkylaki
Newegg.com - Computer Hardware, Hard Drives, ssd kit
Newegg.com - OCZ OCZSSDUPGDKIT1 SSD Upgrade Kit
Newegg.com - SAMSUNG 830 Series MZ-7PC128N/AM 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD) Notebook Upgrade KitLast edited by MegalosSkylaki; August 10th, 2012 at 08:17 AM.
Hard drive clicking sound
By jutah in forum Technical SupportReplies: 4Last Post: October 8th, 2006, 02:22 PM -
Sound and Video problems, among others, with new hard drive.
By seph80 in forum Storage RelatedReplies: 2Last Post: January 9th, 2006, 02:04 AM -
Hard Drive interferes with sound
By carajean206 in forum Multimedia and AudioReplies: 8Last Post: June 4th, 2005, 04:37 PM -
My hard drive makes a clicking sound and then my PC hangs all of a sudden...
By Mave Datthews in forum Storage RelatedReplies: 3Last Post: January 12th, 2005, 07:52 AM -
What Sound is a hard drive meant to make?
By Linkin' Park in forum Storage RelatedReplies: 1Last Post: January 31st, 2002, 07:14 PM
Hi kensan81 I am from the support team at Babylon company. Babylon Search and Toolbar are meant to be a part of an integrated set of tools that help people understand and explore their world....
Remove Babylon search engine
