Thread: RCA HDTV monitor 52in.
June 20th, 2012, 09:28 PM #1Junior Member
- Jun 2012
- 1
I can use remote or push the on button , the green light comes on than shuts off will not come on. Repeat over and over. Green light comes on than will go off again !!! No tv.... Help please!!!!!
June 21st, 2012, 10:37 AM #2
Without knowing the model number, It sounds like a power supply issue...
◄ it is what it is ►
June 21st, 2012, 11:17 AM #3
Sounds, like RCA has the same bad parts.
It is nothing you can fix yourself.
Mine worked intermittently for a while, then did what you described, all the time.
It would cost more to fix, than a new one.
Welcome to TechIMO!
This is a little out of our expertise, as we are a computer tech sight.Hard Sayin Not Knowin
June 21st, 2012, 11:51 AM #4
As Big said, without knowing the model number, we can do little other than guess. If it is still under warranty, I would recommend contacting RCA about it. There support site is located HERE.
There is usually little that an end-user can do to fix TV issues of this nature. Often they will need the expertise of a specialist.
Welcome to TechIMO.
Good job, friend-of-friends!
June 21st, 2012, 10:09 PM #5
Check to see if the air filter is clean, assuming it has one it will be behind a little door in the back... check the manual.
They usually give a blinking light warning first...Obama: The rich have the Federal Reserve and the poor have Harry Reid... LOL. Life really is unfair!
52" RCA HDTV monitor
By sbo in forum Technical SupportReplies: 0Last Post: March 25th, 2011, 04:30 PM -
RCA 52 " HDTV
By redbug331 in forum General Tech DiscussionReplies: 9Last Post: October 1st, 2010, 12:56 PM -
HDTV RCA 52 inch Will Not Power on.
By lukzter in forum General Tech DiscussionReplies: 1Last Post: September 24th, 2009, 11:09 PM -
rca hdtv won't turn on
By sukapral@netzero in forum Technical SupportReplies: 1Last Post: January 28th, 2009, 12:30 PM
Well, that was indeed the point of the original post. A made-up scandal about something that, at the very most, involved a fine detail of Marine protocol, not applicable to any of the other services...
