Results 1 to 6 of 6
    Feb 2003
    scotland
    201
    monitor has no signal and or is going to sleep
    Hi guys hope you can help me out, the other night when I tried to acess my PC
    All I got was no signal and on other monitor was going to sleep I tried a working
    Grafix card but still the same, I even tried stripping it down but still get the same
    I was thinking that it was sleeping/hibernating but can't wake it up I have even tried
    Striping it down to the bare bones but I still get the same, I have even tried anothe
    PC but still the same if any one can help that would be great
    Thx neill
    Jan 2003
    Outside the box
    8,489
    4
    I'm a bit confused by your post.
    Are you saying you've tried two different monitors on the first PC and it won't run. You then tried the original monitor on a second known working PC and its not running on their either?
    Feb 2003
    scotland
    201
    Hi, yes that seems to be the issue, I no the monitors work as it is highly unlikly that both monitors have broke at the same time, as I said above I then tried another PC with same monitor but still the same, I have also tried another monitor on the 2nd PC but all I get is the above issue, am at my wits end with this as I don't no how to continue, I am starting to think its either interference or its a ghost lol, thx
    Jan 2003
    Outside the box
    8,489
    4
    Yeah unless there was a power surge or something that killed both PCs and both monitors it would be highly unlikely they all went dead at the same time.
    So what is the common denominator here? What are you using that is common to both setups? Perhaps the same cables? power strip? or outlets?
    Feb 2003
    scotland
    201
    Quote Originally Posted by RicheemxX View Post
    Well I have already tried different cables power cables, and tried plugging into another power outlet but still the same, I no the monitors work coz I took them into my neigbours and rigged them up to see if they were the problem but they worked, am still scratching my head with this one, any more suggestionsn thx
    Feb 2003
    scotland
    201
    monitors
    hi guys hope someone can point me in the right direction, both my PCs arent sending a signal to my monitors, dont know whats going on, i know they work coz i have rigged up the monitors to a laptop just to see if they work and they do, was thinking that it was the onboard grafix, but tried to install a grafix card but when i do that it still doesnt send a signal to the monitor,
    neill...
  1. monitor goes to sleep mode during games
    By shimivaknin in forum Graphics Cards and Displays
    Last Post: November 26th, 2012, 04:22 PM
  2. Monitor goes into sleep mode
    By Marixi in forum Technical Support
    Last Post: August 10th, 2011, 05:40 PM
  3. My Monitor wont open after switching off to sleep mode
    By cool boy in forum Technical Support
    Last Post: October 22nd, 2005, 09:00 PM
  4. card has monitor in sleep mode
    By angelindesgise in forum Graphics Cards and Displays
    Last Post: September 25th, 2005, 11:10 AM
  5. one monitor goes to sleep mode, another is fine
    By rh71 in forum General Tech Discussion
    Last Post: February 12th, 2003, 12:34 PM
