Results 1 to 10 of 10
    Ultimate Member Interrupt's Avatar
    Sep 2011
    The Villa Straylight
    1,561
    4
    Storm - 0x00000078 & Fail to Load XP CD
    After a short power outage a Dell Dimension 8400 with Windows XP won't boot to Safe Mode or Windows and won't use the "Last Good Configuration." It reports the following:
    System Battery Voltage Low. Upon striking the key to continue booting it gives me a BSOD reading 0x00000078.
    System did have a standard power strip but I guess it didn't do much to protect it.
    To me the System Battery Voltage Low means that the CMOS battery needs to be replaced. But usually does it BSOD if you skip/continue to boot? I didn't think so anyway. So the only thing I can think it could be is a PSU issue caused from the electricity or a fried HD. I've seen all the help pages out there on this particular stop code but not all of them have the same solutions.
    If someone can help me resolve this I'd greatly be appreciated. Perhaps it is only the CMOS battery (I do have experience putting them in and I'm willing to try it). Let me know.
    “Arguing with anonymous strangers on the Internet is a sucker's game because they almost always turn out to be—or to be indistinguishable from—self-righteous sixteen-year-olds possessing infinite amounts of free time.” ― Cryptonomicon
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    It could be the hard drive or any other piece of hard ware that got fried.
    Sep 2011
    1,561
    4
    Anyway to be sure? Is it worth even swapping the CMOS battery out to try it? I could just call Dell I guess but the technician in me would be mighty ticked off doing that.
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    I'd try swapping the CMOS battery, but that error code is indicative of a hardware problem.
    NOVA
    33,803
    46
    Have you run a hard drive diagnostic and check out memTester86+ to start?
    Sep 2011
    1,561
    4
    Quote Originally Posted by GroundZero3 View Post
    Memtest86 finished 1 pass without error.
    Ran Vivard 0.4 from the UBCD with a surface scan, no errors (HD is a Phillips, I believe, so not seeing a specific tool other than Vivard on UBCD for diagnosing Phillips HD errors in this manner which is why I used it).
    I want to run a chkdsk or sfc so I inserted my XP CD and while it is starting (Windows blue setup screen), I get an error:
    STOP: c0000221 Unknown Hard Error
    \SystemRoot\System32\ntdll.dll
    Don't quite know what to do now (will try more Stress Tests while waiting for replies). If it was a HD error or Windows corruption, why would it error when booting the Windows XP Setup CD? That sounds like RAM or something else. But memtest reports the RAM is fine. Blah! Could it just be the CMOS battery? I've never heard of a CMOS battery causing errors like this.
    Some options --
    1.) I do have a multimeter handy, I can test the PSU. 2.) I also have a SATA/IDE-to-USB recovery cable I can use on a working system, if I used that hard drive using the cable - if it is a hard drive problem - I shouldn't be able to access the drive normally without error, correct? Is this worth doing?
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    Did you let Memtest run overnight? That's what you need to do.
    Sep 2011
    1,561
    4
    Also stupid seek floppy drive at boot failure... instead of CMOS battery voltage error now. Don't have a floppy drive, so disabled this in the BIOS. Now no error, but still getting the BSOD right after win logo.
    Quote Originally Posted by Taxman
    At the moment I've performed the following tests:
    On UBCD
    Memtest 86 - 1 full pass, all tests involved
    - Vivard - HD surface scan is fine
    Hiren Boot
    - HDAT2 check & repair of HD revealed no problems
    - HDAT HD seek test is fine
    - Windows Memory Diagnostic is fine, 2 passes using LRAND, Stride6, WMATS+, WINVC, INVC... etc.
    - Chkdsk fine, minor errors but nothing significant.
    - Running S&M Stress Test in Hiren right now in Mini XP mode.
    Do you think I should let memtest run overnight or focus on something else?
    Banned
    Feb 2009
    KFNL FS2004
    11,886
    I had a bad stick of RAM. I was having corrupted downloads and Firefox was acting strange. I ran Memtest with just one pass and found no errors, I ran it overnight and found the errors. So when running Memtest it's always a wise idea to run over night.
    Sep 2011
    1,561
    4
    12 passes, 12 hours. No errors.
    So to reiterate the hard drive and memory tests all come up errorless. I'm still getting that BSOD and XP CD errors out. I'll try ordering a dell factory reset CD if they have one but unsure if it'll work.
  1. "Meteor" & "Storm" Episodes
    By SiliconJon in forum IMO Community
    Last Post: July 29th, 2009, 08:30 PM
  2. There can be only one! Err, maybe 8,9,10....
    By RobRich in forum IMO Community
    Last Post: March 23rd, 2007, 08:12 PM
  3. Guildwars Err=5
    By Klawicky in forum Networking and Internet
    Last Post: April 30th, 2005, 06:46 PM
  4. Nvidia Nforce 2 Sound Storm & Logitech Z-640 Speakers
    By ruthless in forum Technical Support
    Last Post: October 3rd, 2003, 07:37 PM
