Page 1 of 2 1 2 LastLast
Results 1 to 20 of 33
Thread: Wrong CPU Speed
    Aug 2012
    20
    Wrong CPU Speed
    I bought a new motherboard for almost a year i think. My CPU used to be a Core 2 Duo 2.18GHZ because ever sinced i changed the motherboard , every program , BIOS , and windows too show me 1.87 GHZ. I have to mention that i updated bios to the latest. I think something is wrong anyway , cuz at my computer it shows me 1.87 and 1.86. Also in bios looks like only one core is working the other one is 0. THx for help
    NOVA
    33,788
    46
    What motherboard do you have?
    Aug 2012
    20
    Sry , forgot to mention , MSI G31-TM P-21
    Aug 2012
    20
    ill get to bios to write here the facts , im not so pro , this is what i thought that is showing only one working
    Aug 2012
    20
    This are the bios details
    CPU FAN SPEED - 1270 and varies
    SYS FAN SPEED 1940 and varies
    SYS FAN SPEED 2 - 0
    CPU VCORE - 1336 and varies between 1336 and 1320
    3.3 V - 3.392 V
    5 V - 5.129 V
    12 V - 12.488 V
    NOVA
    33,788
    46
    MSI Global – Mainboard - G31TM-P21
    have you looked over the manual?
    Aug 2012
    20
    yes , but cant seem to find anything related to this, i have that manual even physically , and couldnt find nothing in it , if you guys cannot me , the ultimate solution would be MSI forums
    Minnesota
    17,366
    Quote Originally Posted by WaldhorN View Post
    SYS FAN SPEED 2 - 0
    3.3 V - 3.392 V
    5 V - 5.129 V
    12 V - 12.488 V
    um... this info has very little to do with the CPU, you listed your System and CPU Fan speeds, as well as the PSU's Voltage Rails coming into the system.
    Your not even looking in the right place for any CPU Relevant info.
    Minnesota
    17,366
    Check the CPU or DRAM Overclocking options if there is any, that is most likely where you will find any info on the CPU's clock speeds.
    Also if Intel's Speedstep is enabled in the Bios anywhere, disable that and save the settings, reboot and see if that helps.
    Minnesota
    17,366
    I'm looking at the manual right now (Page 24), you need to access the Cell Menu option in the bios...
    as GZ suggested you need to read over the Manual for the motherboard, what you need is in there most likely, at least gives you a good idea of where and what to look at.
    What is the exact model of your CPU, at least this way you can look it up online, find out what its CPU FSB setting should be at, and make sure that it is set right in the Bios settings.
    You listed it as a Core 2 Duo, but what model of C2D?
    Aug 2012
    20
    Aug 2012
    20
    And by they way i got it on Cell Menu , ill post the info right away
    And i have Fail Safe Defaults Settings loaded on the motherboard. You might say now to load optimized defaults , but its the same thing
    Aug 2012
    20
    Intel EIST - Enabled
    ADJUST CPU FSP FREQUENCY - 266
    ADJUSTED CPU FSB FREQUENCY - 1862
    FSB-DRAM RATIO - AUTO
    ADJUSTED PCI-E FREQUENCY - 100
    AUTO - DISABLE DRAM / PCI FREQUENCY - ENABLED
    SPREAD SPECTRUM - ENABLED
    These are the settings that Optimized Defaults shows , i switched to fail-safe a couple of minutes ago , and FSB RATiO - 7 appeared , and INTEL EIST got disabled , hope it helped , i am really looking forward to solve this
    Aug 2003
    Gateshead U.K.
    11,310
    Are you sure this CPU ever ran at the higher speed?
    Does CPU-Z report the CPU model number as a Core 2 Duo E6400, or is this what you remember from when you first built the system?
  15. #15
    Aug 2012
    20
    i am absolutely sure , and no it doesnt , it reports it as 6320 , and i wonder why , i am sure it was 6400 , i even have the old books and stuff , from my old motherboard
  16. #16
    Aug 2012
    20
    anyway i still think that something is totally wrong with the motherboard or the processor , because cpu-z shows the multiplier x6 , and in bios the multiplier is x7 , i started to get nervous now , wtf is wrong with this system ??
  17. #17
    Aug 2012
    20
    Gonna post a screenshot with cpu-z
  18. #18
    Aug 2012
    20
  19. #19
    NOVA
    33,788
    46
    CPU-Z is reporting you have the e6320 intel chip dude, not the E6400 as you claim
    Intel® Coreâ„¢2 Duo Processor E6320 (4M Cache, 1.86 GHz, 1066 MHz FSB))
    So your cpu/speed is fine
  20. #20
    Minnesota
    17,366
    in any case, Speedstep is enabled, disable that, EIST.
    as to what you thought the speed was, was the system Ever Overclocked, or was it run at stock speeds. Was this a prebuilt PC or one that you put together back then?
  1. wrong cpu speed shown
    By big_buick in forum Motherboards
    Last Post: November 12th, 2005, 11:36 PM
  2. Wrong CPU Speed
    By Blessy in forum Technical Support
    Last Post: October 16th, 2005, 12:38 PM
  3. CPU wrong speed
    By Cook_1 in forum General Tech Discussion
    Last Post: July 13th, 2005, 05:08 PM
  4. CPU Runs @ Wrong Speed!!!
    By iced amd in forum Technical Support
    Last Post: October 23rd, 2004, 10:44 PM
  5. Mandrake - CPU wrong speed
    By Krishnawhite in forum Processors, Memory, and Overclocking
    Last Post: April 4th, 2004, 05:15 PM
