August 16th, 2012, 01:58 PM #1Junior Member
- Aug 2012
- 3
A problem with GTX 560 ti! Please help!
Hello everyone,
So, I bought a GTX 560 ti from EVGA 6 months ago, it was working really well until taday. I was playing nfs pro street when suddenly my pc shutdown. I tried many things and I found out it was the gpu which was causing trouble. I removed it from my system and my pc worked fine......but as soon as I plugged 560 ti in it it would not want to start...the whole system. The question is, when I removed the 2x6pin connectors the card started as well as the system, obviously there was no display. I don't understand the problem with gpu (GTX 560ti), now I am using my old 9500GT and everything is working as it should. So I want to ask, why is my gpu not working? Does it short circuits when I plug the connectors, or what? And I have a 700 watt PSU. Sorry for the long post. Your replies will be much appreciated.
Thanks!
My PC specs:
Processor: Intel Core i5 3570k
Memory: G.Skill 8GB RAM
PSU: Xilence 700 watt ( model: XP700)
Motherboard: Asrock Z77 Extreme 4
GPU: EVGA GTX 560 Ti
Hard Drive: Western Digital Caviar Black 1TBLast edited by 001theracer; August 16th, 2012 at 02:57 PM.
August 16th, 2012, 02:00 PM #2
Make and models of all your hardware especially the PSU
August 16th, 2012, 02:19 PM #3Junior Member
- Aug 2012
- 3
My PC specs:
August 16th, 2012, 05:24 PM #4
have you tried testing the system with another power supply, a good quality PSU?
Your systems specs as listed really only needs a 500W range unit, so if you have something or someone you know has a good quality 450-500W Range PSU, you should be able to use it to test with.
with what you listed as symptoms, it could be the video card, or it could be the power supply.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
August 17th, 2012, 09:48 AM #5Junior Member
- Aug 2012
- 3
Yep, I tried it with another psu, and a whole different system of my friend, he has a 600 watt Corsair, but the same problem, the system won't start. And when I unplug the card, pc runs flawlessly.
I think the problem is with the card......its still in warranty so, I should replace it.
August 17th, 2012, 01:11 PM #6
was this a brand new card from EVGA, or did you buy one of their Recertified Cards?
if its brand new I would probably use the Warranty on it, if its Recert, it usually only has a 90 day warranty, but I'd check with them anyways, see if they'll make an exception or something, I have heard of that happening, so maybe they will.
if you've tried in another system, and especially with a Corsair 600W, then I would say the card is probably the culprit, not sure what it could be on the card, but definitely the card could be the problem.i7 940//Corsair H60//EVGA X58 SLI LE//6GB Corsair Vengeance 1600MHz//2x EVGA GTX 560 Ti FPB SLI//NZXT Hale82 850W//CM 690 II Advanced//Win7 64//WD 74GB V-raptor, 750GB Black, 1.5TB Green
Can my pc run a gtx 560?
By Kabir 360 in forum Graphics Cards and DisplaysReplies: 29Last Post: July 20th, 2012, 03:36 PM -
GTX 560 Ti
By AnthonyFz in forum Graphics Cards and DisplaysReplies: 3Last Post: July 18th, 2012, 09:51 PM -
Problems with my GTX 560
By Chris134 in forum Graphics Cards and DisplaysReplies: 59Last Post: March 20th, 2012, 11:13 PM -
GTX 560 TI for this PC?
By ultimaratio in forum Graphics Cards and DisplaysReplies: 3Last Post: December 4th, 2011, 07:54 PM -
The GTX 560 TI
By Taxmancometh in forum Graphics Cards and DisplaysReplies: 58Last Post: August 23rd, 2011, 03:56 PM
running would kill my knees, but i do walk several miles a day.
